need help with simple case statement — Parallax Forums
laser-vectorlaser-vector Posts: 118
edited 2010-09-22 23:11 in Propeller 1
hi all
im trying to sample from an analog joystick, in this case im setting up a deadzone with a case statement
RCValue is the variable from the joystick axis (between 0 - 4880)
CON
  deadzone = 100
  joy1y    = 4880
CASE RCValue
       ((joy1y/2)-deadzone)..((joy1y/2)+deadzone)     : outa[2]~~
       RCValue > ((joy1y/2)+deadzone)                     : outa[2]~
       RCValue < ((joy1y/2)-deadzone)                     : outa[2]~
the first part of the case statement works perfectly, however the parts where RCValue is compared to be either grater than or less than is not working.
how is this done?
    edited 2010-09-22 17:08
    See page 59 - 61 of the propeller manual for a description of the case statement.
    You need to remove "RCValue" from the last 2 lines for them to be correct.
  • AribaAriba Posts: 2,695
    Something like:
    CASE RCValue
       0..joy1y/2-deadzone                 : outa[2]~
       joy1y/2-deadzone..joy1y/2+deadzone  : outa[2]~~
       joy1y/2+deadzone..joy1y             : outa[2]~
    but I would do it with if..else:
    if RCValue < joy1y/2-deadzone
         outa[2]~
      elseif RCValue > joy1y/2+deadzone
         outa[2]~
      else
         outa[2]~~
    Andy
