need help with simple case statement
hi all
im trying to sample from an analog joystick, in this case im setting up a deadzone with a case statement
RCValue is the variable from the joystick axis (between 0 - 4880)
the first part of the case statement works perfectly, however the parts where RCValue is compared to be either grater than or less than is not working.
how is this done?
CON
deadzone = 100
joy1y = 4880
CASE RCValue
((joy1y/2)-deadzone)..((joy1y/2)+deadzone) : outa[2]~~
RCValue > ((joy1y/2)+deadzone) : outa[2]~
RCValue < ((joy1y/2)-deadzone) : outa[2]~
how is this done?
You need to remove "RCValue" from the last 2 lines for them to be correct.
but I would do it with if..else:
if RCValue < joy1y/2-deadzone outa[2]~ elseif RCValue > joy1y/2+deadzone outa[2]~ else outa[2]~~Andy
