BabelProp: Prop in an Atmega328 format — Parallax Forums
TubularTubular Posts: 4,771
edited 2010-09-19 16:37 in Propeller 1
I have to admit, designing pcbs in animal shapes sure beats rectangles
  • wjsteelewjsteele Posts: 697
    edited 2010-09-18 16:38
    I love it!!! But, the name seems familar to me... Hmmm (http://forums.parallax.com/showpost.php?p=876923&postcount=11)
    Fantastic job!!!
    Bill
  • HarleyHarley Posts: 997
    edited 2010-09-18 16:53
    I've laid out a number of pcbs, and don't understand why the 28-pin through hole IC shorts out the 44-lead SMD Prop at the 4 corners.
    I suppose cost is no object. I'd guess this non-rectangular shape will cost extra to route.
    There should also be a bypass cap on each set of Power pins on the Prop. Only appears to be one.
    A number of traces appear to be at other than multiples of 45°. Does the plot process allow this? Sometimes this can be a problem.
    Nice shape. Is the shape serve a purpose? Just curious.
  • TubularTubular Posts: 4,771
    edited 2010-09-18 18:13
    @Bill, hey I read that thread a while ago and had forgotten. Guess it was stuck in my subconscience as a good name. There are lots of good names in that list by McTrivia. Fortunately there are plenty of fish names to choose from, I'll see what I can come up with instead. GuppyProp? Sounds a bit much like PuppyProp
    @Harley, the shape is just for fun, but it does make it look a lot smaller than the equivalent bounding rectangle. Most pcb fabs won't charge for external shape routing (since they route out of a larger panel anyway), just for internal routing.
    As for why the pins short - not sure what you mean, they just do. I will be cutting off 4 pins of the prop.
    tubular
    edit: Regarding bypassing, its a good idea (especially for overclocking), but not essential. Note Spin Stamp by Parallax only has a single bulk cap
    edited 2010-09-18 19:06
    From 'here', pins 5, 10, 19, 24 of 28-pin DIP appear shorted to two leads each of the Prop.
    I suppose the leads you'll be cutting off are those corner ones?
    edited 2010-09-18 20:30
    @Harley, you're correct, if nothing else works I'll be cutting off the four prop corner pins before soldering the QFP down.
    I haven't completely given up hope on squeezing a resistor between those pins and the header contact, just have to see whats possible once the proto boards come back.
    Btw for the protos I'm using DorkbotPdx.Org, in your neck of the woods. The board cost works out to a little under $2 each in sets of 3, and they don't charge for external routing. It seems like an awesome service.
    cheers
    tubular
    edited 2010-09-18 21:29
    Tubular,
    That's really cool, except now I have a challenge for you so you can optimize the amount of board real-estate...
    TWO different circuit designs... One a FISH, and the other a BIRD. (See attached image) :smilewinkgrin:
    468 x 460 - 88K
    edited 2010-09-19 02:22
    The Prop ProtoBoard has 2 x 1uF monos for bypassing. The traditional 80MHz should be fine but I am not sure anyone has fully loaded a pcb with only a singly bypass cap.
    Maybe a Flounder - it has quite a large shape. So does Bream and Snapper. My fish book is on my boat and of course I am not.
    edited 2010-09-19 09:51
    Tubular wrote: »
    Heck no... you use that name... it's perfect!
    Bill
    edited 2010-09-19 11:15
    Douglas Adams would be proud of you. Is that actually going to fit in your ear?
    edited 2010-09-19 14:31
    Heater. wrote: »
    There is precisely *one* way to find out!
    Actually Heater now you have me worried - perhaps I should have included a warning message about it being "not suitable for auricular interfacing"
    tubular
    edited 2010-09-19 14:35
    wjsteele wrote: »
    Bill
    Thanks Bill... I did try to change the name of the thread to "babel328" but without success... must look into how that is done for future reference
    cheers
    tubular
    edited 2010-09-19 14:39
    Tubular,
    Beau, now there's a fun challenge! Hmmm what would a bird shaped Prop board be good for...
    I really like the work of M C Escher... thanks for that
    tubular
  • SapiehaSapieha Posts: 2,964
    edited 2010-09-19 14:43
    Hi Tubular.
    It is possible to change Thread name ---> BUT only from first post. --->
    EDIT - Advanced
    Tubular wrote: »
    tubular
    Sapieha wrote: »
    Hi Tubular.
    EDIT - Advanced
    Thanks, but I tried that. It changes the title on my first message to Babel328 instead of BabelProp, but all others replys have BabelProp in their message, as does the forum index.
    There must be something I'm missing...
