BabelProp: Prop in an Atmega328 format
Tubular
I have to admit, designing pcbs in animal shapes sure beats rectangles
Tubular
Fantastic job!!!
Bill
I suppose cost is no object. I'd guess this non-rectangular shape will cost extra to route.
There should also be a bypass cap on each set of Power pins on the Prop. Only appears to be one.
A number of traces appear to be at other than multiples of 45°. Does the plot process allow this? Sometimes this can be a problem.
Nice shape. Is the shape serve a purpose? Just curious.
@Harley, the shape is just for fun, but it does make it look a lot smaller than the equivalent bounding rectangle. Most pcb fabs won't charge for external shape routing (since they route out of a larger panel anyway), just for internal routing.
As for why the pins short - not sure what you mean, they just do. I will be cutting off 4 pins of the prop.
tubular
edit: Regarding bypassing, its a good idea (especially for overclocking), but not essential. Note Spin Stamp by Parallax only has a single bulk cap
I suppose the leads you'll be cutting off are those corner ones?
I haven't completely given up hope on squeezing a resistor between those pins and the header contact, just have to see whats possible once the proto boards come back.
Btw for the protos I'm using DorkbotPdx.Org, in your neck of the woods. The board cost works out to a little under $2 each in sets of 3, and they don't charge for external routing. It seems like an awesome service.
cheers
tubular
That's really cool, except now I have a challenge for you so you can optimize the amount of board real-estate...
TWO different circuit designs... One a FISH, and the other a BIRD. (See attached image) :smilewinkgrin:
Maybe a Flounder - it has quite a large shape. So does Bream and Snapper. My fish book is on my boat and of course I am not.
Heck no... you use that name... it's perfect!
Bill
There is precisely *one* way to find out!
Actually Heater now you have me worried - perhaps I should have included a warning message about it being "not suitable for auricular interfacing"
tubular
Thanks Bill... I did try to change the name of the thread to "babel328" but without success... must look into how that is done for future reference
cheers
tubular
Beau, now there's a fun challenge! Hmmm what would a bird shaped Prop board be good for...
I really like the work of M C Escher... thanks for that
tubular
It is possible to change Thread name ---> BUT only from first post. --->
EDIT - Advanced
Thanks, but I tried that. It changes the title on my first message to Babel328 instead of BabelProp, but all others replys have BabelProp in their message, as does the forum index.
There must be something I'm missing...
