Salvaging USB plug off of Propeller Proto USB board
I took hacking a bit literal when I could not un-solder a compass module from my proto USB board and I am now trying to salvage parts from the board.
I would like to use the USB port.
It looks like the blue traces encircle four pinholes adjoining the port. Does this mean these pin holes are linked to VSS,RES,TX,RX? Is their a schematic for this board?
I tried soldering leads to the four pinholes. The plug is recognized by windows but no chip is found. I reversed the leads and still nothing. Assuming the
pinholes are not connected to the prop plug.
