XBee Tutorial - Chapter 5 Draft "Network Topologies & Control Strategies"
Steph Lindsay
Hello Interested Parties,
I have attached the Chapter 5 draft pdf of the upcoming XBee Tutorial, once again with comments enabled in Adobe Reader. (Note: PDF has been updated.)
See the Chapter 1 thread for more details on the project. An index of the chapters posted to date is included in the Wireless Index Sticky Thread.
Feedback is encouraged! You can email me directly (editor@parallax.com) or reply to this thread.
Thanks much,
-Steph
Thanks much,
-Steph
Working on Chapter 6 all....
-Martin
-Martin
The've been working flawlessly since early spring, monitoring and controlling my chicken coop, shop lights and watching the driveway for visitors.
I'm working on the API chapter now, but I wasn't going to use the the Stamp with API, just the propeller for passing data. As you can find in some of the forums, the BASIC Stamp & API Mode is very limiting for passing data.
Both sides do not need to be in API mode for passing data. You can have the PC's XBee in API mode and the Stamp side in AT mode - though it is dependent on what you need have done.
-Martin
Al
Yep, I get it too.
It is scrambled for me as well.
Thanks! That's why I'm posting the drafts - I can be busy formatting the next chapter while y'all are proofreading the last one!
:smilewinkgrin:
The figure is fine in the first Draft pdf (which I downloaded), but it is messed up in the Draft 2 pdf linked at the top of this thread. I just retried it and still got the distorted diagram.
Al
