BS2 and switching regulator LT1303 — Parallax Forums
john_sjohn_s Posts: 369
edited 2010-08-31 21:05 in BASIC Stamp
Theory of operation:
Upon the press of "START BS2" push-button the BS2 is supposed to operate from 2x1.5V = 3V batteries.
The LT1303 DC-DC converter is implemented in between the 3V battery pack and the Stamp to boost the 3V to 7V.
The bottom circuit in attached jpg proves that it works as expected.
However, (see the first 2 circuits in jpg) when placing a 2-transistor interface between a push-button and input to the DC-DC converter the LT1303 dies and does NOT supply enough voltage to BS2.
Without the BS2 load all 3 circuits perform identically, i.e. I can measure close to 7VDC at the LT1303 switcher in all three configurations.
One idea's that the PNP transistor is not driven hard enough and kills the 3V Vin to the switcher to something around 2V making it hard to generate any higher Vout. To prove otherwise I connected its Base to GND for a moment - no effect other than some heat (as expected when omitting a base to gnd resistor :-)
I must be missing something obvious...
Any advice on why the first 2 circuits do not work as expected?
    edited 2010-08-28 09:27
    You're presenting the topic.
    How about leading us through your theory of operation?
  • john_sjohn_s Posts: 369
    edited 2010-08-30 12:49
    ... continuation
    There must be a better way to isolate a 3V battery from the following booster circuit.
    This circuit uses way too much current to do just that.
    Any comments/ideas?
    800 x 371 - 26K
    edited 2010-08-30 13:43
    There is nothing in those circuits to keep the power on once the pushbutton is released. Is that the goal? If so, it needs positive feedback. For example, you could connect another resistor from a Stamp output back to the base of the 2N3904, and then make that Stamp output high right at the top of the program to hold the power on. To cycle everything off, make that pin low.
    If you use a pmosfet, it will have to be a very low threshold type. "logic level", "trench" or "vertical channel" are words that go with that type. Vgs=<1Volt.
    There should be a resistor of say 10kΩ from the 2N3904 base to ground. Same thing, 10kΩ from base to emitter of the '3906.
    The resistor to the pushbutton (220Ω as shown on your schematic) should be more like 1 kΩ. Put the 220Ω between the collector of the '3904 and base of the '3906. Directly connecting the '3906 base to ground may have fried that transistor.
    edited 2010-08-30 15:10
    Tracy,
    Thank you for reviewing it...
    With the intention to use just 2 C-size batteries to power the BS2 I expected to come-up with the simple DC-DC solution. The disappointment came when I was loosing the battle with LT1303 and its in-rush current. In shown configuration the LT1303 still keeps shutting down when confronted with the load of around 80mA. At higher currents all I can get out of it is well below 5V and that does not even want to start the BS2. I would not even mention the battery current that I'm seeing then :-)
    Yes, as you pointed out there's an additional circuitry (see attached jpg) that I omitted for simplicity.
    Regards, John
    800 x 371 - 32K
    800 x 686 - 75K
    edited 2010-08-30 16:36
    On your 'scope trace I see a blue line that increases up to around 6.3 V, and a red line that goes up to around 2.8V. What are those? The window says LTspice-- simulating or breadboarding?
    You might try a beefier transistor in place of the 2N3904. For bipolar I swear by the Zetex e-line, for example the ZTX1149A is a superbeta PNP, modified TO92, pulsed Ic of 3 amps, and about 100mV in saturation with 3mA base drive and 0.5Amp collector current. A transistor like that can make a world of difference. There are nice pmosfets out there too. Are you working in thru-hole or SMT?
    edited 2010-08-30 18:44
    These are simulation curves... where BS2 is substituted with 80 Ohm load resistor (so that Vout/Rload = around 80mA)
    GRN line = Vout of LT1303 shows that it reaches 6.3V at R load
    BLUE line (kind of overlapping with the GRN line) proves that LT1303 is capable to deliver at least that much current i.e. close to 80mA
    RED line = Vin to LT1303 as measured at collector of 2N3906
    I will try Zetex line, although both old and proven 2N3904 and 2N3906 are also known for their low VCEsat below 0V3.
    A switcher is all SMD on its own PCB, while the rest is mix and match - see attached some pics of my actual circuitry.
    Now, why the 80mA circuit - despite its successful simulation - refuses to work with the simple switch?
    However, it works perfectly without a button circuitry as seen on "80mA works only wout button.jpg"
    480 x 360 - 43K
    480 x 360 - 38K
    480 x 360 - 49K
    edited 2010-08-30 23:19
    Can you measure the voltage at the input with a multimeter (or better yet a 'scope), to see what it is actually happening? Maybe there are spiky current demands that the transistor cannot supply, but the switch does okay. It's all well and good that the simulation says that it should work, but... when it's not as expected, it has to be inspected.
    edited 2010-08-31 09:13
    I contacted LTC and it seems that there are some issues with this kind of arrangement...
    Perhaps there's a good reason for not using any front end ON-OFF circuitry when using switchers with certain higher load current. You can find plenty of examples showing ON-OFF circuitry placed BEHIND the switcher but I yet to come with the appnote describing the same placed IN FRONT OFF the switcher.
    As far as current spikes - I am sure they are all over the place during first few milliseconds as the simulation shows currents reaching 2A (!) Perhaps the strait battery acts here as a filter to those momentary spikes or shorts and has no problem handling them, while the transistor circuitry cannot cope with these states at all - and makes the switcher hard to turn on.
    edited 2010-08-31 11:18
    The LT1303 does have a shutdown pin, which reduces the current to 10µA. Is that too much for your application? C cells at 5Ah capacity would theoretically last over 50 years at that discharge rate! The control circuit would have a pullup to hold it off, and a pushbutton or Stamp to activate and keep it on by holding the pin low.
    A 2N3906 can't supply 2A pulses. Was the transistor model worked into the LTspice simulations?
    edited 2010-08-31 12:54
    Tracy,
    I was doing it in the past in my other design where I used SHDN pin but it still requires some in-series MOSFET to disconnect the load behind LT1303 so that it is isolated from "naked" Vbat as seen via L and the Schottky diode...
    However, just before going that way I suddenly realized my mistake... so here it goes :-)
    Well, after making a mistake (or was it ? ...) in answering to you I thought that I mistakenly said "12A" instead of "2A"... I realized that only after my reply went out and tried to correct it afterward. But then, it struck me that I really saw current simulated at even higher values. Sooo... what was the cause of it??? The HUGE cap in front of the switcher of course!
    Way it went to be conveniently replaced with u1 SMD and voila - the circuit's alive!
    Now, 100uF sits in parallel to the battery (where it supposed to be in the first place) to ease up its burden when working towards the switcher. Hats off to the basic - errr.. "..elementary my dear Watson" [ACD] :-)
    p.s. thanks Tracy for steering my brain towards thinking. It took me only 2 weeks or so before I decided to look at it from other angles. Well, never too late to correct NOW obvious mistake in design... btw, I'm still waiting for the guy from LTC to come up with their answer. As soon as I get it I'll post it here as well.
    Good deal! I'm glad it's working. That makes sense.
    I forgot about the path through the inductor and the diode. A load cutoff at the output, such as the one on page 10 of the data sheet, might do the trick too. But yours achieves a lower, near zero current.
