Mark Forums Read (again)
OK, while I'm logged in there are no problems. It all works as expected.
Once I log out all forums seem to be randomly marked to have (no) posts. The link on the front page Mark Forums Read has no effect.
While not being logged in I can enter a forum and mark it as read from the quick link submenu. Going to the front page then shows it as read. Logging in and immediatly out again reverts the forum I just marked to have unread posts (again).
Is that a known effect, something that can be fixed easily? Is it by any chance timezone related? It certainly is annoying!
BTW, this is just an assumption of how it works, not actual knowledge
Log off the forum, then clear all your cookies. For a couple days, the "last read" stuff on the new forum was cookie-based, and it still tracked unread posts after logging off. But that was changed to the current userid-based tracking system. I'm thinking that, if any of those old cookies are around, you may be seeing their lingering effects.
That did the trick. Thanks Phil.
