SMT prop and single sided PCB
Graham Stabler
I'm making a very light weight propeller platform on a flexible laminate (like mylar but heat proof), I need to use the surface mount version of the propeller but obviously need to be careful about the ground loops to protect the PLL. I can probably do a double sided PCB but vias under the propeller are probably not practical. Any suggestions on a reasonably robust layout?
I have several less than professional ideas if I get stuck but I wanted to check before getting desperate.
OK before I posted I tried one idea for a low profile via, I cut a short slot in the laminate with a scalpel and pushed a rectangle of copper film through the hole, folded down on each side and then soldered before the excess was removed with braid. Works quite well, might be an option.
Graham
Graham
If using the TQFP there are of course many options. There was a recommended design block posted some time ago by Parallax to minimise PLL failures.
Graham
Graham
