SMT prop and single sided PCB — Parallax Forums
Graham StablerGraham Stabler Posts: 2,510
edited 2010-08-12 01:34 in Propeller 1
I'm making a very light weight propeller platform on a flexible laminate (like mylar but heat proof), I need to use the surface mount version of the propeller but obviously need to be careful about the ground loops to protect the PLL. I can probably do a double sided PCB but vias under the propeller are probably not practical. Any suggestions on a reasonably robust layout?
I have several less than professional ideas if I get stuck but I wanted to check before getting desperate.
OK before I posted I tried one idea for a low profile via, I cut a short slot in the laminate with a scalpel and pushed a rectangle of copper film through the hole, folded down on each side and then soldered before the excess was removed with braid. Works quite well, might be an option.
Graham
  • TubularTubular Posts: 4,771
    edited 2010-08-11 23:14
    Sounds interesting. Are you using the QFN prop? Because as I see it, that leads you to have a big ground pad common underneath, no vias under the prop, and radial Vdd's.
    If using the TQFP there are of course many options. There was a recommended design block posted some time ago by Parallax to minimise PLL failures.
    edited 2010-08-12 01:32
    I am using the TQFP. The recommended design is double sided and includes vias under the propeller which is the problem I have been trying to solve.
    Graham
    Ah So I suppose if I use the QFN then that does mean vias around the prop which would be easier. Not easier to solder though!
    Graham
