upload picture no, avatar yes — Parallax Forums
JeffaJeffa Posts: 80
edited 2010-08-25 11:00 in General Discussion
Regarding uploading a picture in the forum user profile
For what it's worth while brining my profile etc. up to date after the forum software change I note that using the same thumbnail .jpg 100 x 74 2.22 kb I could not successfully upload it in the picture section of the profile. I tried from an upload browse and from a url several times. The same picture uploaded as an Avatar on the first try.
Has anyone else experienced similar dificulties?
I just attached the picture in question to this message. In compose preview it shows as a broken link. I'll attach some other jpg and see if that works. They both show broken. I'll save this and see if they display.
    edited 2010-08-10 17:30
    Yes I had the same problem. I ended up uploading the picture three times and the avatar three times, and it started displaying the jpg but still kept saying the upload had failed. Since the jpg was the same for picture and the avatar, I still can't say which one actually worked.
    A couple of those failed uploads might have been because the .jpg was 121 pixels wide instead of the max 120.
    So you are saying it is the avatar?
  • JeffaJeffa Posts: 80
    edited 2010-08-10 18:11
    Dr_Acula wrote: »
    Yes I had the same problem. ... So you are saying it is the avatar?
    Correct. I was able to upload the avatar not the picture. I don't know what the difference might be. It seems that in the context of this forum software they are the same. Perhaps the picture only displays in the profile. ??? I duno...
  • $WMc%$WMc% Posts: 1,884
    edited 2010-08-10 19:01
    just checking my Avatar
    1st: It still doesn't work
    2nd: Mistakingly clicked on bitmap and not the jpeg pic.
    3rd: Have Avatar,all is well!
  • W9GFOW9GFO Posts: 4,010
    edited 2010-08-10 19:25
    Jeffa wrote: »
    How did you attach the images? Why is is it that I cannot click on them to open them but I can right click and open them in a new tab? And why does it say "Attached images" rather than "Attached thumbnails"? Why, why why???
    Anyhow, I did not have any issues uploading a profile picture, although it did get resized in the process.
    Rich H
    edited 2010-08-10 22:20
    Signature gimmick
    edited 2010-08-10 22:35
    Jeff
    Working Your Post, Thanks
    Sig test
    ReCon1
    "setfocus"
    I uploaded them as content when composing the post.
