new forum limits? — Parallax Forums
new forum limits?
ratronicratronic Posts: 1,451
edited 2010-08-15 01:46 in General Discussion
Hi everyone - I know Mr. Ewald has much to do right now, but maybe somebody else can answer this. When the new forum gets finished will we be able to post attachments and images at least as large as we could in the old forum?
  • Jim EwaldJim Ewald Posts: 733
    edited 2010-08-08 21:42
    The limits are generally larger. Images have size (dimension) limits to prevent super wide images from breaking the overall page layout. We can adjust upward as required.
    edited 2010-08-08 21:53
    Thanks Jim
    edited 2010-08-09 10:59
    Is there a quick and easy way to know the dimensions of the photo?
    Humanoido
  • W9GFOW9GFO Posts: 4,010
    edited 2010-08-09 11:03
    Just for images, you can create a photo album and load images into it. If they are too big, they will be automatically resized. You can then copy the url of the image and use it inline in a post.
    An image attachment size limit of 800 x 800 has been recommended, seems good to me.
    Rich H
  • SapiehaSapieha Posts: 2,964
    edited 2010-08-09 11:08
    W9GFO wrote: »
    Rich H
    It is NOT so simple -->
    I mostly use Images captured from screen and after resizing them are not readable in most cases.
    edited 2010-08-09 11:22
    Here's an 800 x 800 screen capture. I tried to upload an 800 x 1,200 but it was resized by the forum.
    How much bigger do you need?
    Rich H
    800 x 800 - 88K
    edited 2010-08-09 12:10
    W9GFO wrote: »
    Rich H
    Hi W9GFO
    I have NOT problems with resizing pictures when them are posted as IN LINE
    BUT in attachments it is not good idea AS many times it is needed to send entire Print Screen image - On my computer it is -> 1920x1080 but I know some one have bigger resolutions.
    800 x 450 - 60K
    edited 2010-08-09 12:36
    I understand. I wonder if there is the ability to only resize the inline image. Probably not.
    However, a zip attachment can be up to 4.77 MB.
    Attached is a 1680 x 1050 screen capture.
    Here it is inline using DropBox;
    Rich H
  • WhitWhit Posts: 4,191
    edited 2010-08-09 13:05
    Humanoido wrote: »
    Humanoido
    Humanoido,
    I use a piece of freeware called Paint.net. It will let you do all sorts of things to your images including crop and resize to a specific size. Hope this helps!
    edited 2010-08-09 13:09
    I have hundreds of posts and none of the images were resized after the transfer to the new forum. What is the solution for this?
    edited 2010-08-09 13:15
    W9GFO wrote: »
    Rich H
    Hi W9GFO
    BUT start open Yours Attachment ---> IT is resized and very ugly
    THAT IS PROBLEM
    edited 2010-08-09 14:06
    Sapieha wrote: »
    Hi W9GFO
    THAT IS PROBLEM
    I downloaded it, and opened it. It does look bad at first because it displays at less than 100% to enable the whole image to fit within the window. Make it full size and it is fine.
    Are you sure that you are viewing it at 100%?
    Rich H
    edited 2010-08-09 14:09
    W9GFO wrote: »
    Rich H
    Yes If You download .zip
    BUT use Thumbnails to open it
    edited 2010-08-09 14:38
    Ahh... Now we are getting somewhere. This software deals with a larger inline better than the old stuff did. Cool.
    edited 2010-08-09 14:49
    Sapieha wrote: »
    I removed the thumbnail for my post that has the huge image in it. That was the result of uploading as an attachment and it was severely compressed as a result. I did not intend to leave it there.
    DropBox is a very easy solution. Just save your image into the dropbox public folder, right click and copy the public link.
    You could use it as a link to the image like this or display it inline.
    Rich H
    edited 2010-08-09 14:58
    W9GFO wrote: »
    Rich H
    Hi W9GFO
    Sorry if I say it on that way.
    If I need download software that are not Part of ATTACHMENT system on forum THAT is already VERY BAD.
    We have attachment box in EDIT window and if it work correctly --- NO needs for that EXTRA software.
    Is not Computer that shall control ME, It is I that will control it in way I know is possible.
    edited 2010-08-09 15:51
    In my opinion having threads on this forum full of images that are on different system like Dropbox is a really bad idea.
    It's all out of control then. One day DropBox will drop of the net or get moved and bam there goes the integrity/consistency of the threads here.
    edited 2010-08-09 16:01
    Then that is a very good argument for being very generous with file size limits.
    Rich H
    One thing I now notice about this forum that's different from the old one is that a post that's wider than my browser window does not make the whole page too wide -- just the one post. In the old forum, that was not the case. One too-wide image would screw up the entire page for viewing. For that reason, I would say that there's less of a reason to put a pixel limit on image attachments.
    OTOH, I can see absolutely zero justification for displaying an entire 1920 x 1440 screen capture inline. That's an absurd waste of pixels and a huge annoyance to try to view. If you want to display a screen dump, either resize the window before capturing it, or crop it afterwards. The portion of a window required to make one's point in the forum virtually never takes up an entire large screen.
