Supply voltage for #27982 433Mhz Transceiver modules
RobotWorkshop
According to the datasheet the #27982 433Mhz transceiver modules can run from a 3.3V to 5V supply. Is there any advantage to running them at 5V vs 3.3V? Just curious if the range may be better when using the modules at 5V. If no one has done has done a comparison yet it may be worth performing some range testing at both voltages to see if there is a difference.
Robert
Robert
- Stephen
You can find the TRM information @ http://www.linxtechnologies.com/Documents/TRM-xxx-LT_Data_Guide.pdf
