infrared sensor (irs) help
I have several irs's installed through out my building in seperate rooms to control the lights for energy conservation.· Is there·something I can put in·one room that will cause the lights in that room to remain on without a person having to pass through it that can be easily removed?
I'm just guessing, though.
If it's like most PIRs, then EACH sensor has a field of view that it breaks up into a number of independently monitored sectors. As a person moves through ONE room, that person will move from sector to sector in the ONE sensor's field of view, and when the ONE sensor detects things are changing from sector to sector, that's when it triggers its electronic circuit. The only thing I don't know is how to make a cheap and easy far infrared emitter. Several small incandescent lights might work, but you'd probably have to get the spacing just right so you're sure each sector of the sensor will get triggered.
I hope that helps.
www.panasonic-electric-works.com/peweu/en/downloads/ds_61802_0002_en_napion.pdf
media.digikey.com/pdf/Data%20Sheets/Panasonic%20Electric%20Works%20PDFs/AMN%20Design%20Manual.pdf?cshift_ck=null&client_id=5042
- Stephen
Hi, sorry to intrude, but my question is related to this comment. Is it wrong to have 2 PIR's in the same room? I want to make my AC turn off when I leave the room, and I am thinking about using a PIR, but there is already one in there used by the security system. Would one cause erronous readings to the other?
No, it's not wrong. PIR stands for "Passive Infra Red". Passive means it does not emit any energy (like the way a radar emits energy then waits to see if energy returns, for example). Instead, a passive sensor merely observes the infra red spectrum to see if any changes have occurred in the environment, and if changes have occurred, then it triggers an alarm or whatever. What these sensors detect is the heat from a person's body or from some other warm object, but they only trigger if that person or object is moving.
So, you should be able to install as many PIRs as you like, and they won't interfere.
hope that helps
Thank you so much! It will help.
So they only work with warm objects, apparantly they are tested with a warm black object with a forked wheel in front of them. I tried it with a couple of IR leds, but it never reacted.
There's an interesting graph about this on this data sheet:
http://media.digikey.com/pdf/Data%20Sheets/Panasonic%20Electric%20Works%20PDFs/AMN%20Design%20Manual.pdf?cshift_ck=null&client_id=5042
