Problems with Memory stick datalogger. — Parallax Forums
mosquito56mosquito56 Posts: 387
edited 2010-07-29 20:59 in Propeller 1
· I can't get my datalogger to work.
·· In uart mode the chip looks like it is loading. The lights blink red/green, the thumbdrive reads and the stick shows solid red, ready. I·keep getting a non-sync error. I am using the exact wiring diagram from the uart page.
In uart mode, if the drive is not in the program detects this.
· In spi mode, no action on the datalogger at all and I only get "no drive inserted error"
I have flipped the spi-uart jumper on both sides in all 4 combo's no luck.
I have tried all the programs from the library in all compinations. I have·triple checked all wires.
I tried 2 different thumbdrives the smaller is 2gb.
I have been using the sd card with no·problems ·but want to update to usb.
Unfortunately my computer died and I now have a windows 7 machine. I can't tell·how my thumbdrives are formatted but I think they are fat16 since that is what I was using with my old·windows xp machine.
I purchased the datalogger about 2 years ago. It has been sitting in the bag until now.
Don
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
    edited 2010-07-29 17:52
    mosquito56,
    I use a USB datalogger a lot.· I have two of them (they are for sale) but I've only found a couple of USB drive that will work with them.· I plan to stop use the USB datalogger all together and just use SD cards.· I originally purchased the USB datalogger because the SD card stuff looked to intimidating.· I now find the SD cards are easier to use and almost all cards I've tried work great with the Propeller.· With Kye's new object you can use huge SD cards (I'm using an 8Gig with to problems).
    If you already know how to use SD cards I'd suggest continuing with them.
    If you still want to use the USB datalogger, try to find other drives to test.· I've found older drives are more likely to work and make sure they aren't larger than 2Gig.
    Have you tried reading or writing to the drives after you get the error messages?· One of my USB drives that does work still gives me error messages.
    Duane
  • mosquito56mosquito56 Posts: 387
    edited 2010-07-29 18:49
    Sorry to hear you say that. I doubt that I can find an older usb drive but I will keep an eye out. I am very happy with the sd card I just wanted to exteriorly mount the usb as external mount of the card reader will be difficult.
    thanx for the input.
    Don
  • T ChapT Chap Posts: 4,260
    edited 2010-07-29 20:19
    The datalogger has been one of the most frustrating devices on the forum. I have never used the Parallax datalogger, but do use the Vinculum chip all the time and it works fine for me with all the drives I have tried. Can you post the code you are using that produces the errors? I think you should also make sure the drives are formatted on a PC.
    I only used the code from the obex. Datalogger uart, dataloggerspi. I changed no code, only wired it up and tried to run it. I have only been using the drives on my pc for transferring files from dead computer to new computer.
