Board of Ed. and Homework board differences?
Gramps
Are there any differences in the electronics between the Board of Ed. and the Homework board?
Gramps
'What is your life?"
"It is even a vapor that appears for a
little time and then vanishes away."
Saint James 61 A.D.
Gramps
Saint James 61 A.D.
The Board of Education also has special connectors for servos or similar 3-wire devices. The equivalent can be set up on the Homework Board's breadboard area, but they're ready-to-go on the BOE.
It seems that code runs slightly different on the two boards.........
Saint James 61 A.D.
Is that the symptom you're getting? "they run slightly different" is a pretty vague description.
I'm seeing a reset on the homework board that doesn't happen on the BOE.
It's giving me the jitters"..........
Thanks, Gramps
Saint James 61 A.D.
