Board of Ed. and Homework board differences?
![Gramps](https://forums.parallax.com/uploads/userpics/025/nR8RRLNDKI5B8.jpg)
Are there any differences in the electronics between the Board of Ed. and the Homework board?
Gramps
'What is your life?"
"It is even a vapor that appears for a
little time and then vanishes away."
Saint James 61 A.D.
Gramps
Saint James 61 A.D.
The Board of Education also has special connectors for servos or similar 3-wire devices. The equivalent can be set up on the Homework Board's breadboard area, but they're ready-to-go on the BOE.
It seems that code runs slightly different on the two boards.........
Saint James 61 A.D.
Is that the symptom you're getting? "they run slightly different" is a pretty vague description.
I'm seeing a reset on the homework board that doesn't happen on the BOE.
It's giving me the jitters"..........
Thanks, Gramps
Saint James 61 A.D.
