Visual Spin: Pre-Alpha Release download link — Parallax Forums
RaymanRayman Posts: 15,068
edited 2010-07-23 17:10 in Propeller 1
Started talking about Visual Spin ideas in this thread:
http://forums.parallax.com/showthread.php?p=923817
If anybody is really, really brave and won't mind if their computer is destroyed,
you can try out a pre-alpha release from my website:
http://www.rayslogic.com/propeller/Programming/VisualSpin/VisualSpin.htm
This project has just begun, so it is very incomplete.
But, I thought some people might find it interesting...
Here's a screenshot, in case you're scared:
My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • Bobb FwedBobb Fwed Posts: 1,119
    edited 2010-07-22 20:21
    That's a 10 on my cool-o-meter! I will definitely try this when it is no longer bent on destroying my computer!
    April, 2008: when I discovered the answers to all my micro-computational-botherations!
    Some of my objects:
    MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
    Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
    String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
    Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
  • RaymanRayman Posts: 15,068
    edited 2010-07-22 20:52
    Just in case anybody is trying it... You can select a form object either by double-clicking on it in left tree-view window, or single-clicking on it in the main view.
    Then, you can edit it's properties in the Properties window on the right....
  • FredBlaisFredBlais Posts: 380
    edited 2010-07-22 22:41
    This is definitely really cool. I was looking for something like that for a long time. Keep up the great work!
    By the way, is your version of the software is more advanced? I can't see anything to delete the buttons or other objects and generate the spin code, from your delay generator, you seems like having other controls, like radio buttons...
    edited 2010-07-22 23:22
    FredBlais, Thanks for trying it! As I've said, this program is in the very early stages of development. But, I think I've overcome all the programming hurdles... There were a few things I had to learn how to do...
    Anyway, yes, being able to delete objects is next on the agenda... Then, need to add in more components. I think I'll add a code view where you can type in custom code and event handlers too...
    The delay generator was made by hand. I.e., without the aid of a program like this. But, Visual Spin would have made writing that code almost trivial!
  • zappmanzappman Posts: 418
    edited 2010-07-22 23:50
    Just tried it on my computer running Vista, without any problems.
    Can't wait until it does more.
    Visit Zappman's Blog at Savage Circuits
    edited 2010-07-23 09:24
    Very glad to hear it's working on another compter. I've really only sorta tested it on one, also running Vista, 64-bit.
    But, I don't really have any reason to believe it won't work everywhere. It's built with the standard MS Visual Studio C++ with no 3rd party
    additions.
    Without actually testing it much, I wanted to post some cautions though...
    Also, this is the "debug" version.· You should get a "Debug Assertion Failed" message if something goes wrong...
    Post Edited (Rayman) : 7/23/2010 9:42:03 AM GMT
  • donovandonovan Posts: 1
    edited 2010-07-23 12:02
    I'll play around with it on a 32 bit XP machine and a 64 bit Windows 7 machine this weekend and let you know how it goes. Looks like it could end up being a nice little addition to the prop universe!
    Donovan.
  • jknightandkarrjknightandkarr Posts: 234
    I've downloaded it, I'll try it on my computer later after work tonight.
    Joe
    I'm going insaine. It's SOOOOOO much fun. lol
