help with xbee
I'm having trouble setting my xbees (I use the xbee pro 900 xsc modules from sparkfun)to communicate with each other so I'm trying to narrow down the posiable reasons why.
Could somone check this code and tell me if I'm doing something wrong in my software and not my hardware?
All that I get out of my x-ctu terminal screen is: .ut.......
Con
'Pins
xbeetx = 2
xbeerx = 3
signal = 19
_clkmode = XTAL1 + PLL16X
_Xinfreq = 5_000_000 '80 MHz
OBJ
xbee: "Xbee_Object"
Pub start |l
led
waitcnt(80_000_000+cnt)
xbee.Start(3,2,0,9600)
XBee.AT_Init
waitcnt(80_000_000*5+cnt)
led
xbee.dec(9999)
xbee.str(string("Hello!",13))
repeat
led
Pub led |hold
hold:=cnt
dira[noparse][[/noparse]signal]:=1
outa[noparse][[/noparse]signal]:=1
waitcnt(hold+8_000_000)
!outa[noparse][[/noparse]signal]
I have just tried your code with two xbee's type ·xb-24 and·it works ok.
Gerry
Is the garbage correlated with transmissions from the other XBee? That is, does it start and stop as you start and stop the·transmitting XBee?
Can you communicate with each of the XBees through XCTU when they're directly connected to your computer?
What are your settings (MY, DL, PANID, etc.)?
