Why won't the music play?!?
I have a Propeller setup with 4 pushbuttons (pulled up), an SD card, audio out, and my Graphics Slave (and hardware). I have the setup on the PPDB and all worked fine. Then I transfer it to a demo board & protoboard setup and the sound wouldn't work. I soon discovered that if I so much as touched the USB cable with the USB socket casing, the music would start playing. I re-did my setup to all feed out of the demo board's power supply and to use a different prop setup and the same thing happens. It will still work on my PPDB, though.
What is wrong?
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
What is wrong?
Micro
The only other thing that comes to mind is to check all the connections around the FTDI chip, USB connector, and surrounding parts.
Andrew Williams
WBA Consulting
PowerTwig Dual Output Power Supply Module
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
