Rubber Feet for Chassis — Parallax Forums
kt88seampkt88seamp Posts: 112
edited 2010-07-10 18:13 in General Discussion
I am looking for rubber feet bumpers for a chassis for one of my projects. I want them to be screw down and to be able to accommodate a 10-24 inch screw. The head of the screw is somewhere between 5/16 and 3/8 inches. The head is about or 1/8 inch high.
  • hover1hover1 Posts: 1,929
    edited 2010-07-09 20:19
    One search is www.mouser.com for 3M bumpers:
    http://www.mouser.com/Search/Refine.aspx?Keyword=3M+bumpers
    kt88seamp said...
  • T ChapT Chap Posts: 4,260
    edited 2010-07-09 23:40
    Try Misumiusa.com or mcmaster.com both have products like that.
    edited 2010-07-10 00:32
    Doh! McMaster should have been my first choice also!
    Jim
    T Chap said...
  • kt88seampkt88seamp Posts: 112
    edited 2010-07-10 04:42
    I don't think there is such a thing as a rubber bumper that can accommodate a 3/8" head. I looked everywhere. So is there anything that will cover the screw in the bottom of my chassis so it does not scratch my table?
    edited 2010-07-10 04:55
    Some ideas:
    1. Replace the screws entirely, using bumpers with threaded studs.
    2. Use plastic screw caps (won't provide any anti-skid properties, though).
    3. Use self-adhesive bumpers that are thicker than the screw heads, positioned elsewhere on the bottom of your unit.
    McMaster-Carr carries all of these items. (Boldface phrases are the search terms.) Except for the studded bumpers, your local hardware store probably has them, too.
    edited 2010-07-10 05:09
    What about a slightly over tightened rubber grommet with a flat screw head? A round head will defeat the effect.
    Beau Schwabe
    IC Layout Engineer
    edited 2010-07-10 05:57
    McMaster carries 10-32 bumpers with threaded studs (bumpers that have a a 10-32 threaded screw rod) but they are too big, 1 inch in diameter and 5/8 inch high. I need it 3/4" inch or smaller and 3/8" high or shorter.
    edited 2010-07-10 06:27
    In that case, I'd go with the self-adhesive kind and call it good.
  • K2K2 Posts: 694
    edited 2010-07-10 06:45
    "So is there anything that will cover the screw in the bottom of my chassis so it does not scratch my table?"
    Depending on your level of desperation, hot-melt glue and silicone rubber will both do the job. With a modicum of cleverness, the latter can look quite nice.
    "Let's not bicker and argue about who killed who."
  • TonyWaiteTonyWaite Posts: 219
    edited 2010-07-10 11:17
    Why not use poly-elastomer 'snap in' bumpers?
    They're cheap, effective and easy to assemble: just select for the appropriate panel thickness and
    latch into place.
    I've used thousands for bus/rail products.
    T o n y
    edited 2010-07-10 12:17
    Rubber stoppers from a lab supply house can be drilled to accept 10-24 (or larger) screws, or you can mount studs in them. Available in a large range of sizes.
    I settled on some screw caps. They are chrome colored but that can be fixed with some spray paint.
