Anyone create an I2S object for the Prop?
Timothy D. Swieter
I2S - Inter-IC Sound http://en.wikipedia.org/wiki/I%C2%B2S
Spec: www.nxp.com/acrobat_download2/various/I2SBUS.pdf
This could have some fun applications. I glanced at the spec, bit timing is very important, but I was unsure how exacting we can be with the Prop clocks to generate the exact timing needed. This is something I will look into after I get Spinneret much further along.
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
www.tdswieter.com
In particular I've always wanted to build some kind of all digital light organ (or some kind of other visualization). I haven't looked into the toslink spec to see if it'd be possible to decode raw toslink s/pdif digital audio on the prop, or if it'd be smarter to use something like the minidigi board to convert the s/pdif into I2S, and deal with the I2S on the prop. I think these particular boards do two 16-bit channels at 48 K samples per second. It's another one of those projects far out on the horizon that I'll probably never get to...
The products on minidsp look cool.
www.tdswieter.com
