VGA DE-15 connector query: IDC-crimp ribbon parts? — Parallax Forums
TonyWaiteTonyWaite Posts: 219
edited 2010-06-23 16:42 in General Discussion
Hi all,
Is anyone aware of an IDC version of the 3 row-by-five 15-way VGA connector?
I am looking to source male and female genders to make twenty-off VGA link ribbon cables; and hand-soldering
takes an age!
I've tried the usual UK suspects (RS, Farnell, Mouser, Digikey) but have so far found nothing.
T o n y
    edited 2010-06-23 16:00
    I doubt you will find any. The reason is that the ribbon pitch would have to be equal to the pin pitch divided by three, rather than two, as is the case with two-row DB connectors.
  • TonyWaiteTonyWaite Posts: 219
    Cheers Phil,
    I'm convinced of your logic here and will just have to grit my teeth and get on with
    making them up the hard way!
    Thank you,
    T o n y
