5V Power for Propeller based PCBs using miniUSB connector — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2010-06-23 13:41 in Propeller 1
I am using the miniUSB-AB connector to power·my new pcb designs. Here is why...
  • brings in regulated 5V from a number of sources (many people already have them)
    • mobile phone,·camera chargers (110/240V ac)
    • mobile phone,·camera· chargers (12V car cigarette plugs)
    • PC's via a USB connection
    • Powered USB hub
  • cables from miniUSB to USB are plentiful (many have them)
  • miniUSB-AB is lower profile
  • takes less space
The miniUSB-B is the standard for many phones, cameras, etc. So why the miniUSB-AB ?
  • miniUSB-B is the standard for a device
  • the AB connector allows·either A (host) & B (device)
  • with the new semi-complient USB drivers·done by Micah we may be able to connect to
    • PC's and other hosts
    • devices such as
      • USB memory sticks
      • Bluetooth
      • WiFi
    • All we require is a cable
  • I can use·the miniUSB-AB·elsewhere (I am buying in bulk)
So, if the pcb contains a pair of links from 2 prop pins (series resistors will probably be required) that link to this connector, then we may be able to utilise this connector for a connection to other hosts (which will then supply 5V power to our pcb). It will not work with devices unless we breakout the cable to get 5V from elsewhere, but this is still an option.
It just makes sense to me to use a miniUSB-B or miniUSB-AB for 5V power.
Post Edited (Cluso99) : 6/21/2010 7:20:19 AM GMT
