PINK replacement
Heys
Since i lost my PINK last month and can't order a new one (my ISP blocks port 80), i'm searching for a replacement, wich i can modify the portnumber (above 1024)
Helping hand here needed!
You can read more about it here:
http://forums.parallax.com/showthread.php?p=915751
And here:
http://forums.parallax.com/showthread.php?p=896606
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
The Spinneret Web Server would be a good replacement for PINK, but it is still a work in progress.
Tell me more about how you use the PINK module. I am interested in learning how customers apply that product and what features they like and don't like and what they wish they had for features.
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
I followed many howto websites, like portforwarding.com and this one: http://www.boutell.com/newfaq/creating/forwardports.html
In the middle of that page you will find the steps for the SMC Barricade G.
@ 5: Add an entry with "LAN IP Address" 192.168.2.11, "Protocol Type" TCP&UDP, "LAN Port" 80, "Public Port" 80, and the "Enable" box checked.
Seems easy but, i don't have a LAN port and Public port field. Only a Service port, just one field where i can enter text.
Last year i decided to buy another one after some search on the net: A linksysWRT54G.
At home the same problem. Jut one field, a service port.
Looks like· i only can forward 80 to 80?
www.tdswieter.com
I called a local shop who sells routers, seems that our local ISP (s) are involved in selling those products.
Maybe i can find a router on the web.
**edit**
Maybe this site will help with forwarding on your WRT54G
portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
EOD Memorial
Post Edited (eod_punk) : 6/18/2010 2:18:32 PM GMT
http://tumbler.is-a-geek.com:9100/index.html
www.tdswieter.com
have another router right now.
Now i can setup my sms server. [noparse]:)[/noparse]
www.tdswieter.com
When running the first time:
The NDK-IP settings are wrong
giving: IP: 192.168.2.127
I had to modify it to 192.168.0.102 manually
Using Win 7
I remember my first PINK settings,using XP where correct.
Maybe a bug?
