PINK replacement — Parallax Forums
PINK replacement
TumblerTumbler Posts: 323
edited 2010-06-23 11:29 in General Discussion
Heys
Since i lost my PINK last month and can't order a new one (my ISP blocks port 80), i'm searching for a replacement, wich i can modify the portnumber (above 1024)
Helping hand here needed!
    edited 2010-06-17 14:43
    Well, I don't know if this counts as a "replacement" or not, but have you heard about the upcoming Spinneret Web Server?
    You can read more about it here:
    http://forums.parallax.com/showthread.php?p=915751
    And here:
    http://forums.parallax.com/showthread.php?p=896606
  • eod_punkeod_punk Posts: 146
    edited 2010-06-17 14:50
    Can't you just forward it to a different port with your router? something like webaddress.com:8080/index.html then forward the 8080 port in your router to the PINK IP and port 80.
    There is no problem that can't be solved with a suitable amount of explosives!
    EOD Memorial
    edited 2010-06-17 23:49
    Has eod_punk said, surely there is a way to deal with the ports problem.
    The Spinneret Web Server would be a good replacement for PINK, but it is still a work in progress.
    Tell me more about how you use the PINK module. I am interested in learning how customers apply that product and what features they like and don't like and what they wish they had for features.
    Timothy D. Swieter, P.E.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
    www.tdswieter.com
  • TumblerTumbler Posts: 323
    edited 2010-06-18 04:13
    The problem i have with portforwarding is this:
    I followed many howto websites, like portforwarding.com and this one: http://www.boutell.com/newfaq/creating/forwardports.html
    In the middle of that page you will find the steps for the SMC Barricade G.
    @ 5: Add an entry with "LAN IP Address" 192.168.2.11, "Protocol Type" TCP&UDP, "LAN Port" 80, "Public Port" 80, and the "Enable" box checked.
    Seems easy but, i don't have a LAN port and Public port field. Only a Service port, just one field where i can enter text.
    Last year i decided to buy another one after some search on the net: A linksysWRT54G.
    At home the same problem. Jut one field, a service port.
    Looks like· i only can forward 80 to 80?
    edited 2010-06-18 06:01
    If you have a WRT54G that is capable of third party firmware, I suspect you can get the router to do anything. However I'm not the expert to tell you. I imagine the idea is this: The router gets a message from the outside world on port XXXX such as www.parallax.com:xxxx. You tell your router to take data on port XXXX and send it to YYYY. So I would guess there would need to be two fields, the incoming and the outgoing - like you wrote, LAN Port (YYYY) and Public Port (XXXX).
    www.tdswieter.com
    edited 2010-06-18 07:53
    Tomothy said...
    My version doesn't allowed that [noparse]:([/noparse]
    I called a local shop who sells routers, seems that our local ISP (s) are involved in selling those products.
    Maybe i can find a router on the web.
    edited 2010-06-18 14:02
    I don't think you really want to forward port 80 anyways. I think you really want to be accessing your PINK from a different port by adding ":8080" to the address of the web page. In your router forward public port 8080 to local port 80 on the PINK IP.
    **edit**
    Maybe this site will help with forwarding on your WRT54G
    portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
    EOD Memorial
    Post Edited (eod_punk) : 6/18/2010 2:18:32 PM GMT
    edited 2010-06-23 10:17
    Plz be kind and test this link to my new PINK and report status here. Thx
    http://tumbler.is-a-geek.com:9100/index.html
    edited 2010-06-23 10:57
    Works from my home in Singapore.
    www.tdswieter.com
    edited 2010-06-23 11:06
    Thx Timothy
    have another router right now.
    Now i can setup my sms server. [noparse]:)[/noparse]
    edited 2010-06-23 11:11
    I'm glad you got your port forwarding figured out. Care to share your solutions for others you may be lurking and having similar trouble?
    www.tdswieter.com
    I have a question about the IPSettup.exe
    When running the first time:
    The NDK-IP settings are wrong
    giving: IP: 192.168.2.127
    I had to modify it to 192.168.0.102 manually
    Using Win 7
    I remember my first PINK settings,using XP where correct.
    Maybe a bug?
