How to get started with pneumatics ?
Bean
I'd like to just control one actuator, what is an easy way to do that with the propeller ?
What hardware do I need ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
Bean
- Stephen
Thanks, but I don't see any electronically controlled pneumatic values ?
Bean
http://www.bimba.com/
Are a couple options. You can also check an local industrial surplus store or electronics surplus store which may have discarded pnuematics from factor automation overhauls. E-bay is another good bet.
Get a valve that is 12V or 24V and then use an appropriate driver such as a darlington array with the proper current rating. Some valves may draw up to 500mA when actuated, the smaller valves should be less.
Timothy D. Swieter, P.E.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
Take a look at Surplus Center for good pneumatic bargins too. www.surpluscenter.com
Tim
I have been in process control for a number of years, but I'm not sure of your application. But if you just want to control a pneumatic actuator with a electronic controller all you would need in a transducer like this one http://www.controlair.com/transducers/550trans.html. It will take a 4-20ma or 1-5vdc signal and produce a proporational pressure out.
Bob
