How to get started with pneumatics ? — Parallax Forums
BeanBean Posts: 8,129
edited 2010-06-23 18:26 in General Discussion
I'd like to just control one actuator, what is an easy way to do that with the propeller ?
What hardware do I need ?
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
There are two rules in life:
· 1) Never divulge all information
If you choose not to decide, you still have made a choice. [noparse][[/noparse]RUSH - Freewill]
    edited 2010-06-23 03:16
    Actuator, pressure source, valve. Some people use a sprinkler valve because they are not expensive. I like these guys for their parts. I find some in the used parts bin at my metal recycler sometimes.
    - Stephen
    edited 2010-06-23 03:44
    Try www.automationdirect.com. They have some inexpensive pneumatic components.
  • BeanBean Posts: 8,129
    edited 2010-06-23 10:37
    Phil,
    Thanks, but I don't see any electronically controlled pneumatic values ?
    Bean
    edited 2010-06-23 12:40
    http://www.smcusa.com/
    http://www.bimba.com/
    Are a couple options. You can also check an local industrial surplus store or electronics surplus store which may have discarded pnuematics from factor automation overhauls. E-bay is another good bet.
    Get a valve that is 12V or 24V and then use an appropriate driver such as a darlington array with the proper current rating. Some valves may draw up to 500mA when actuated, the smaller valves should be less.
    Timothy D. Swieter, P.E.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
    www.tdswieter.com
    edited 2010-06-23 14:48
    Hmm, you're right, Bean. What an odd omission from their product line!
  • Tim-MTim-M Posts: 522
    edited 2010-06-23 16:12
    Pneumatic components are rather recent addition for Automation Direct... I understand more in the line will be coming soon.
    Take a look at Surplus Center for good pneumatic bargins too. www.surpluscenter.com
    Tim
  • BJJohnsonBJJohnson Posts: 24
    Bean,
    I have been in process control for a number of years, but I'm not sure of your application. But if you just want to control a pneumatic actuator with a electronic controller all you would need in a transducer like this one http://www.controlair.com/transducers/550trans.html. It will take a 4-20ma or 1-5vdc signal and produce a proporational pressure out.
    Bob
