Screws for Parallax Standard Servo
I have some screws for the servo with the Parallax standard servo, but I don't have enough for the project I am starting. I haven't been able to find any place that sells screws/bolts in that size. I'm trying to mount onto the X shaped arm that comes with the servo. From what I can tell, the screw size is #0.
Any suggestions on where I can get more of these tiny screws/bolts?
www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=+FUTM2260&search=Go
Jim
(2) is the size and (56) is the threads per inch. You will also see, 4-40, 6-32, 8-32, 10-32 and so on. These are incrementaly larger sizes.
Jim
I thought I read Bolt/Nut in the original post, but it was Screw/Bolt.
I usually use parts like these. All depends on what the OP is trying to attach to the servo arm.
Let's ask him.
Jim
The nyloc nut is a nut that has plastic in it so it doesn't back out. Just like using a lock washer.
Jim
What·size are you looking for? Lengths can be gotten down to 3/8" from quick searches.
Jim
Thanks for helping me figure this out, guys.
Of course, I'm still in the same boat of not being able to find bolts (or screws). I tried the microfasteners site, but it keeps telling me no results found.
http://www.microfasteners.com/catalog/products/MSCMSPP.cfm
or here:
http://www.mcmaster.com/#pan-head-machine-screws/=7mue6n
Jim
Thank you all very much. I really appreciate the help and information.
