9 Volt @ 2600 Lithium-ion Power Pack from Radio Shack for five dollar Hack of t — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2010-06-21 13:34 in General Discussion
I do not know ·if you find any but it might be a great find
They have been mark down and discontinued
Come with a 12 volt @ 1.5 power charger switching
Come with a 12 volt car charger
One note PLEASE use a fuse on your out put
Using any Lithium-ion battery pack with out a fuse or with out battery voltage·sensing board·is asking for BIG trouble
·Now wanting to learn Spin· Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 6/20/2010 1:37:49 AM GMT
  • zappmanzappman Posts: 418
    edited 2010-06-20 01:33
    sam_sam_sam said...
    I do not know if you find any but it might be a great find
    Hi Sam,
    I picked up one of these for $15 at Radio Shack on May 24th, used a $10 off $40 purchase coupon, so it cost a little less then the $15.
    Wish I could find another one, I have been looking.
    Was running my BoeBot off of it, it ran great.
    Also have been running my Propeller Demo Board from it.
    I have not opened my battery up so thanks for the picture of the inside.
    zappman
    Visit Zappman's Blog at Savage Circuits
    edited 2010-06-20 01:38
    I will see if I can find any more and let you know
    I found three of them But I am keeping them
    Sam
    edited 2010-06-20 02:11
    sam_sam_sam said...
    One note PLEASE use a fuse on your output
    </font> </font>
    I will have to look at some more stores in my area.
    I thought this 'Battery Assembly' had some built in output protection, since it has a bunch of circuitry inside, such as the charge circuit and charge level status LEDs.
    But I guess adding a fuse is the safest thing to do.
    It does have the warning 'Do Not Short Circuit Battery' printed on the label
    This is a picture of the robot I am building, you can see my battery connected to my BOE board.
    attach.aspx?a=44100
    Post Edited (zappman) : 6/20/2010 2:32:05 AM GMT
    1024 x 768 - 140K
    edited 2010-06-20 02:24
    It dose· how ever it may be allot higher than 2600 mill amp It would be allot safer to use a fuse
    Here is a link to the type of fuse that I use
    http://www.allelectronics.com/make-a-store/item/RXE-065/RESETTABLE-CIRCUIT-PROTECTOR-0.65-1.3-AMP//1.html
    Sam
    Post Edited (sam_sam_sam) : 6/20/2010 2:29:10 AM GMT
    edited 2010-06-20 02:28
    NOW that look COOL
    ·········································· idea.gif·····
    ·························································································· smile.gif
    Sam
  • edited 2010-06-20 21:15
    sam_sam_sam said...
    Sam,
    This would make a great tutorial if you could teach what fuses or resettable circuit protectors we need for different voltages / amps.
    The reality is my friends and I are using multiple LEDs, LED drivers·and I'm even thinking of multiple servos and motors.· I know these things aren't always exact but safety is a good priority and it isn't too far fetched to think I won't burn out some boards.
    I'm possibily going to look at the Digital I/O board / kit.
    Chuck
    edited 2010-06-20 21:57
    Thanks_thanks_thanks sam_sam_sam!
    Good tip, I found one near my house (LA area). I see what you mean, they're hard to track down, a web purchase only. Most stores aren't supposed to have them!
    Wouldn't mind finding one more...
    edited 2010-06-20 22:31
    Also found 2 wall warts on clearance at the Shack. Great current rating. Curious form factor, though:
    6V, 1800 mA, $1.47: http://www.radioshack.com/product/index.jsp?productId=2049709
    4.5V, 1600mA, $1.97: http://www.radioshack.com/product/index.jsp?productId=2049707· I only found this one.
    Could be made into·a battery charger for a robot, or power a project or BoE.·Includes one adaptaplug to suit !
  • hover1hover1 Posts: 1,929
    edited 2010-06-20 23:14
    @sam_sam_sam
    What is the Radio Shack part number of the Battery Pack?
    @erco
    I cleaned the southeast area out of these·4 months ago @$1.97. I had the Nashville Manager order every one of them that he could get (leagally) in his franchise area. I could only score 6.
    Glad you found some more. I have been running·4 servos off the Propeller Servo Board, (one power supply), with no problems. It's a suprising little PS.
    How do they fit so many electrons into such a small package?
    Jim
    Post Edited (hover1) : 6/20/2010 11:21:49 PM GMT
    edited 2010-06-21 01:14
    @Jim: OH YOU'RE THE GUY who cleaned out all the 6V adapters! [noparse]:)[/noparse]
    All I could find were two 4.5 V units here in LA. Surprisingly, they work fine on my older BoE. The brick outputs 4.65V, and I measure 4.59 volts at the BS2. I was sure that voltage regulator would have dropped it at least 0.5 volt, but far less than that. Just a quickie test, no external circuitry attached, but if that 4.5V brick is rated at 1600 mA, it looks like it will work fine.
    edited 2010-06-21 11:23
    Here is what is on the package of the battery pack
    ·Lenmar Universal DVD Battery····· ··DVDLU923
    ·UPC code # 2952155941
    Sam
    http://www.radioshack.com/product/index.jsp?productId=3557112&clickid=cart
