Sharp 2Y0A21 sensor + Analog to digital TLC0831 problem.
Hello,
I have a Sharp 2Y0A21 distance sensor (10cm-80cm) that I want to connect to my Propeller chip. As the sensor output is analog, I am using an Analog to Digital converter TLC0831 (It suppose to work the same way as ADC0831)
I did my connections following this link:
www.parallax.com/dl/docs/prod/acc/SharpGP2D12Snrs.pdf
I have being testing many codes, but finally I am using the ADC0831_DEMO by Jean-Marc:
obex.parallax.com/objects/248/
My problem is I don't get any result, all the output coming for the TLC0831 is 0.
I have tested the Sharp sensor with a multimeter and it is working good, so I guess the problem is with the TLC0831 connections.
At this point I don't know what else to try, I have attached the pictures of my setting, any suggestion would be appreciated,
Thank you.
Post Edited (Elenssar) : 6/18/2010 2:39:16 PM GMT
Thank you.
The Basics of Breadboarding.
PS. I hope you didn't break your Prop Chip. You have 5 volt going directly to P0
Post Edited (hover1) : 6/18/2010 12:18:52 PM GMT
