DS1302, DS1307, DS32Khz - What do I need to use TIME within BS2 finally?
Hi! I've been trying my best to use time with the StampDock software, to no prevail! I want to really do know what i do need in order to be able to have:
-Time on a chip that I can use with BS2
-Being one that has BATTERY BACKUP
I am hearing all the things about DS1302, then 1307, then DS32Khz (???), please help me - which of those, a combination, or just one, or whatever, and what type of battery do I need to order so I can just end up having all required parts in front of me?
Thanks!
Thanks!
You can buy ready made little printed circuit boards with a DS1302 or DS1307 and a crystal and sometimes a backup battery as well. SparkFun sells one with a DS1307. There's sample code in one of the Nuts and Volts Columns on using an I2C device with a BS2 like on the HomeWork board ("I2C Fun for Everyone").
- Stephen
I posted this yesterday "Code for bs2p40 w/DS1307 timestamp clock w/user control."
I spent some tinme on the 1302 but quickly gave it up because it didn't appear to be a fully integrated Date & time clock that ran independently, was programmable, machine readable·and kept time as well as date, including a 24 hour clock·and leap year compensation.· The 1307 does all that so I chose the DS1307, then I realized Parallax did as well.· When I started my project I bought the Parallax Professional Development Board (PDB) part number 28138.· The PDB comes complete with·a DS1307 and is fully integrated with the microcontroller circuit.· Communicating with the 1307 requires understanding the I2C communication protocol.· Fortunately Parallax has solved this for you by including the I2CIN and I2COUT commands within the BS2 product capabilities.· Sincerely, go look at my posting from yesterday.·
If you don't understand timers and crystal oscillators·you need to take a few more basic electronics courses.· Tell me about your development environment, I'll see if I can point you in the right direction.·
There is also a directive which will allow a Sparkfun serial LCD to show the time - just uncomment the #DEFINE UseLCD
If a "y" is not entered in the DEBUGIN window, code setting the clock·is skipped...
' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' This program demonstrates the access and control of an external real- ' time-clock chip, the DS1307. ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- SDA PIN 0 ' I2C serial data line SCL PIN 1 ' I2C serial clock line ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- Ack CON 0 ' acknowledge bit Nak CON 1 ' no ack bit DS1307 CON %1101 << 4 AM CON 0 PM CON 1 Mode12 CON 1 '12 hour mode Mode24 CON 0 '24 hour mode ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- slvAddr VAR Byte ' I2C slave address devNum VAR Nib ' device number (0 - 7) addrLen VAR Nib ' bytes in word addr (0 - 2) #SELECT $STAMP ' -----[noparse][[/noparse] BS2 Subroutines ]------------------------------------- #CASE BS2, BS2E, BS2SX 'i2cData VAR Byte ' data to/from device i2cWork VAR Byte ' work byte for TX routine i2cAck VAR Bit ' Ack bit from device wrdAddr VAR Word ' word address #ENDSELECT secs VAR Byte ' DS1307 time registers mins VAR Byte hrs VAR Byte day VAR Byte ' weekday date VAR Byte ' day in month, 1 - 31 month VAR Byte year VAR Byte control VAR Byte ' SQW I/O control mode VAR Bit ' 12 or 24 hour mode am_pm VAR Bit ' am or pm (for 12 hour mode) idx VAR Nib ' loop control pntr VAR Byte ' ee pointer char VAR Byte ' character for display ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- DayNames DATA "SunMonTueWedThuFriSat" '#DEFINE UseLCD 'directive to display time on Sparkfun serial LCD - comment line if no LCD #IF UseLCD #THEN ' =========Define names for LCD instructions, bps======= homeCur CON 1 'Cursor home cntl-A bigChar CON 2 'Begin big characters cntl-B regChar CON 3 'End big characters cntl-C noCurs CON 4 'Make cursor invisible cntl-D ulCurs CON 5 'Show underline cursor cntl-E blkCurs CON 6 'Show blinking block cursor ringBell CON 7 'Bell output cntl-G backSp CON 8 'Backspace cntl-H hTab CON 9 'Horizontal tab (4 col) cntl-I curLF CON 10 'Smart linefeed cntl-J vTab CON 11 'cursor up one line cntl-K clrLCD CON 12 'Clear entire LCD screen cntl-L carRet CON 13 'Carriage return cntl-M onBkLight CON 14 'Backlight on cntl-N offBkLight CON 15 'Backlight off cntl-O posCmd CON 16 'Position cursor cntl-P clrCol CON 17 'Clear column cntl-Q ? alignRight CON 18 'Accept right-alignment data cntl-R Esc CON 27 'Escape sequences LCD PIN 15 #ENDIF 'TrueBaud mode for non-inverted 9600-N81 (MAX233a line driver) 'InvBaud mode for inverted, 9600-N81 (direct connect e.g. w/22k ohm) #SELECT $STAMP #CASE BS2, BS2E, BS2PE TrueBaud CON 84 InvBaud CON 16468 #CASE BS2SX, BS2P TrueBaud CON 240 InvBaud CON 16624 #CASE BS2PX TrueBaud CON 396 InvBaud CON 16780 #ENDSELECT ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Reset: slvAddr = DS1307 ' 1 byte in word address addrLen = 1 DEBUG CLS, "Enter 'y' to set date" SERIN 16, TrueBaud, 10000, Skip_set, [noparse][[/noparse]WAIT("y")] 'DEBUG CLS ' Clear The DEBUG Screen SetClock: DEBUG CRSRXY, 0, 0, "Enter 2 dig year", CLREOL DEBUGIN HEX2 year ' Set Year DEBUG CRSRXY, 12, 0, "mth", CLREOL DEBUGIN HEX2 month ' Set Month DEBUG CRSRXY, 12, 0, "day", CLREOL DEBUGIN HEX2 date ' Set Date DEBUG CRSRXY, 6, 0, "week day", CLREOL DEBUG CRSRXY, 0, 1, "1=SUN 2=MON 3=TUE 4=WED 5=THU 6=FRI 7=SAT", CR DEBUGIN HEX1 day 'set day DEBUG CLS DEBUG CRSRXY, 0, 0, "Enter mode 1=12hr 0=24hr", CLREOL DEBUGIN HEX1 mode DEBUG CRSRXY, 0, 1, CLREOL IF mode = Mode24 THEN DEBUG CRSRXY, 6, 0, "2 dig hour, 00-23", CLREOL DEBUGIN HEX2 hrs ' Set Hours (24 Hour Mode) ELSE DEBUG CRSRXY, 6, 0, "2 dig hour, 01-12", CLREOL DEBUGIN HEX2 hrs ' Set Hours (12 Hour Mode) ENDIF DEBUG CRSRXY, 12, 0, "min, 00-59", CLREOL DEBUGIN HEX2 mins ' Set Minutes IF mode = Mode12 THEN DEBUG CRSRXY, 6, 0, "0=AM 1=PM", CLREOL DEBUGIN HEX1 am_pm ' Set AM/PM Flag ENDIF secs = $00 control = 0 ' disable SQW output IF mode = Mode12 THEN hrs = hrs | %01000000 '$40 'set bit 6 high for 12 hour mode ENDIF IF am_pm = PM THEN hrs = hrs | %00100000 '$20 'set bit 5 high for PM ENDIF GOSUB Set_Clock ' block write clock regs ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Skip_set: #IF UseLCD #THEN SEROUT LCD,InvBaud,[noparse][[/noparse]onBkLight] ' Clear the screen. SEROUT LCD,InvBaud,[noparse][[/noparse]clrLCD, noCurs] ' Clear the screen. #ENDIF DEBUG CLS, "DS1307 Demo", CR, "-----------" Main: GOSUB Get_Clock ' read DS1307 IF secs = 128 THEN GOTO SetClock 'clock not set DEBUG CRSRXY, 0, 5, BIN8 hrs mode = hrs.BIT6 'get 12/24 hour bit IF mode = Mode12 THEN am_pm = hrs.BIT5 'get am_pm bit (HIGH = p.m.) hrs = hrs & %00011111 '$1F 'zero bits 5 and 6 ELSE hrs = hrs & $3F ENDIF DEBUG CRSRXY, 0, 6, BIN8 hrs DEBUG CRSRXY, 0, 2, HEX2 hrs, ":", HEX2 mins, ":", HEX2 secs IF mode = Mode12 THEN IF am_pm = PM THEN DEBUG " p.m", CR ELSE DEBUG " a.m.", CR ENDIF ELSE DEBUG CR ENDIF 'BCD to decimal conversion: decVal =(bcdVal.NIB1 * 10) + bcdVal.NIB0 'decimal to BCD conversion: bcdVal = (decVal / 10 <<4) + decVal // 10 'DEBUG DEC (hrs.NIB1 * 10) + hrs.NIB0, " ", DEC (mins.NIB1 * 10) + mins.NIB0, " ", DEC (secs.NIB1 * 10) + secs.NIB0, CR DEBUG HEX2 month, "/", HEX2 date, "/", HEX2 year, CR #IF UseLD #THEN SEROUT LCD,InvBaud,[noparse][[/noparse]posCmd,"46 ", HEX2 hrs, ":", HEX2 mins, ":", HEX2 secs] IF am_pm = PM THEN SEROUT LCD,InvBaud,[noparse][[/noparse]" P.M.", carRet] ELSE SEROUT LCD,InvBaud,[noparse][[/noparse]" A.M", carRet] ENDIF SEROUT LCD,InvBaud,[noparse][[/noparse]posCmd,"26 ", HEX2 month, "/", HEX2 date, "/", HEX2 year, carRet] #ENDIF GOSUB Print_Day PAUSE 100 GOTO Main ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Print_Day: IF day > 7 THEN RETURN pntr = DayNames + ((day - 1) * 3) ' point to 1st char #IF UseLCD #THEN SEROUT LCD,InvBaud,[noparse][[/noparse]posCmd,"20 "] #ENDIF FOR idx = 0 TO 2 ' print 3 letters READ (pntr + idx), char ' read letter DEBUG char ' print it #IF UseLCD #THEN SEROUT LCD,InvBaud,[noparse][[/noparse]char] #ENDIF NEXT RETURN #SELECT $STAMP ' -----[noparse][[/noparse] BS2 Subroutines ]------------------------------------- #CASE BS2, BS2E, BS2SX ' Do a block write to clock registers Set_Clock: GOSUB I2C_Start ' send Start i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Set_Clock ' wait until not busy i2cWork = 0 ' point at secs register GOSUB I2C_TX_Byte FOR idx = 0 TO 7 ' write secs to control i2cWork = secs(idx) GOSUB I2C_TX_Byte NEXT GOSUB I2C_Stop RETURN ' Do a block read from clock registers Get_Clock: GOSUB I2C_Start ' send Start i2cWork = slvAddr & %11111110 ' send slave ID (write) GOSUB I2C_TX_Byte IF (i2cAck = Nak) THEN Get_Clock ' wait until not busy i2cWork = 0 ' point at secs register GOSUB I2C_TX_Byte GOSUB I2C_Start i2cWork = slvAddr | %00000001 ' send slave ID (read) GOSUB I2C_TX_Byte FOR idx = 0 TO 6 ' read secs to year GOSUB I2C_RX_Byte secs(idx) = i2cWork NEXT GOSUB I2C_RX_Byte_Nak ' read control & send NAK to end read control = i2cWork GOSUB I2C_Stop RETURN ' -----[noparse][[/noparse] Low Level I2C Subroutines]---------------------------------------- ' *** Start Sequence *** I2C_Start: ' I2C start bit sequence INPUT SDA INPUT SCL LOW SDA Clock_Hold: DO : LOOP UNTIL (SCL = 1) ' wait for clock release RETURN ' *** Stop Sequence *** I2C_Stop: ' I2C stop bit sequence LOW SDA INPUT SCL INPUT SDA RETURN ' *** Transmit Byte *** I2C_TX_Byte: SHIFTOUT SDA, SCL, MSBFIRST, [noparse][[/noparse]i2cWork\8] ' send byte to device SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cAck\1] ' get acknowledge bit RETURN ' *** Receive Byte *** I2C_RX_Byte_Nak: i2cAck = Nak ' no Ack = high GOTO I2C_RX I2C_RX_Byte: i2cAck = Ack ' Ack = low I2C_RX: SHIFTIN SDA, SCL, MSBPRE, [noparse][[/noparse]i2cWork\8] ' get byte from device SHIFTOUT SDA, SCL, LSBFIRST, [noparse][[/noparse]i2cAck\1] ' send ack or nak RETURN ' -----[noparse][[/noparse] BS2P Subroutines ]------------------------------------ #CASE BS2P, BS2PE, BS2PX ' Do a block write to clock registers Set_Clock: I2COUT SDA, DS1307, 0, [noparse][[/noparse]STR secs\8] ' update clock registers RETURN ' Do a block read from clock registers Get_Clock: I2CIN SDA, DS1307, 0, [noparse][[/noparse]STR secs\8] ' retrieve clock registers RETURN #ENDSELECT
