Simple BS2 Water Sensor Help
Hey guys, i need help to make a simple water sensor that when it gets wet it let's the power flow through it.·So it is basically a switch that turns on when it gets wet. I am making a simple paddleboat out of insulation foam and was going to mount the BS2 and battery supply off the bottom a couple inchs and then have the water sensor on the ground so that·if the stamp finds its watersensor input = 1 then it stops and ENDs the whole program to prevent·a short on the BS2.·I'm just looking for something more or less reliable and simple (if possible a hookup schematic too?)
"WOAH! that wasn't supposed to happen!"
http://www.parallax.com/Store/Books/EducationalTexts/tabid/181/CategoryID/66/List/0/SortField/0/Level/a/ProductID/140/Default.aspx
Dave
Dave Andreae
Parallax Tech Support·
- Stephen
Looking at electrosys's circuits.. i coulda built both warnings from parts on hand...
for the future..I'm thinking of a serial (open drain) networked monitoring system.· With a monitor panel on each floor.·
One master stamp monitoring comms and updating indicators. will need 3 wires that the panels will use to get the SHIFTOUT data. (1 more for 5vdc to sound piezo alarm)
Monitor units will use serial comms to respond to query(s) & report status. (2wires)
Before you criticize someone, walk a mile in his shoes. That way if he gets angry, he'll be a mile away and barefoot. - unknown
