Voltage divider to pull-up servo logic line — Parallax Forums
Thomas FletcherThomas Fletcher Posts: 91
edited 2010-06-03 19:17 in Propeller 1
I am having trouble getting a servo to work. It responds after about 40 seconds when the control
pin is wired straight to the propeller pin.
I am trying a voltage divider to pull up the signal, but I seem to be getting even less "juice" in. Not
pictured but I placed an led on the control line and it is dimmer with this set-up then wired
directly to the propeller pin.
What am I doing wrong?
I got the resisters a while back at radio shack in a pack. I think they were listed as 1/4w. I am
thinking I am reading the color codes wrong or maybe I am wiring it wrong.
Post Edited (Thomas Fletcher) : 6/3/2010 3:15:11 PM GMT
    edited 2010-06-03 17:01
    Most servos should work just fine when wired directly to a Propeller I/O pin. It doesn't make sense that a servo would not respond initially, then respond after around 40 seconds. If it doesn't work with the Propeller's 3.3V logic output, then it should continue to not work. A voltage divider would not help you. If you have to have a 5V signal, you would use a switching transistor as shown in Nuts and Volts Column #6. You'd need to invert the pulses to the switching transistor, but it should be easy to modify whatever code you're using to do that.
  • hover1hover1 Posts: 1,929
    edited 2010-06-03 17:06
    Maybe there is something in your code that is causing a waitcnt to be missed and has to cycle around again, (takes about 50 seconds).
    BTW, I never use a resistor or pullups on my servos. I will use a 5K inline with the control signal when using the Propeller Servo Controller Board because of the Voltage Translators.
  • Thomas FletcherThomas Fletcher Posts: 91
    edited 2010-06-03 17:15
    I hacked the code together from single servo spin and 3-axis(SPI) Spin demo to make
    a camera stabilization platform. The program is suppose to counter rotate the platform
    in response to roll angle.
    Video
    www.facebook.com/profile.php?id=830440549&v=app_2392950137#!/video/video.php?v=451426750549
    Still can not figure out the start-up delay or why it sometimes just stops working.
    CON
      _clkmode      = xtal1 + pll16x
      _xinfreq      = 5_000_000
      CLKPIN        = 7
      DATAPIN       = 6
      CSPIN         = 5
      X_OFFSETVAL   = 28           ' X-Axis offset compensation value
      Y_OFFSETVAL   = 36          ' Y-Axis offset compensation value
      Z_OFFSETVAL   = -138             ' Z-Axis offset compensation value
    VAR
     { long  _X,_Y,_Z,_OldX,_OldY,_OldZ
      long  Z_Rot_Angle, Old_Z_Rot_Angle
      long  Y_Rot_Angle, Old_Y_Rot_Angle
      long  X_Rot_Angle, Old_X_Rot_Angle
      long Stack[noparse][[/noparse]16], x, y, servopos, loaded
    OBJ
      DEBUG         : "Parallax Serial Terminal"
      SPI           : "MMA7455L_SPI_v2.spin"   'Used to Communicate to the Accelerometer
      servo         : "Servocontrol"
    Pub Init
      'Initialize the acceleromter
      SPI.start(CLKPIN, DATAPIN, CSPIN)
      DEBUG.start(250000)
      servo.init
      waitcnt(clkfreq/10+cnt)       'Wait for things to settle for a 1/10th of a sec
      SPI.write(SPI#MCTL, (%0110 << 4)|(SPI#G_RANGE_2g << 2)|SPI#G_MODE) 'Initialize the Mode Control register
      'Write the X, Y, and Z offset compensation values
      SPI.write(SPI#XOFFL, X_OFFSETVAL)
      SPI.write(SPI#XOFFH, X_OFFSETVAL >> 8)
      SPI.write(SPI#YOFFL, Y_OFFSETVAL)
      SPI.write(SPI#YOFFH, Y_OFFSETVAL >> 8)
      SPI.write(SPI#ZOFFL, Z_OFFSETVAL)
      SPI.write(SPI#ZOFFH, Z_OFFSETVAL >> 8)
      'loaded := cognew(read8bitdata(@x,@y), @stack)
      main
    Pub Main
        Repeat
           Read8BitData
           If  x < 2 and x > -2
              servopos := 137
              servo.getposition(servopos)
           elseif x < -1
             Addtoservoangle
           elseif x > 1
             Subtractfromservoangle
           Showdata
    Pub Subtractfromservoangle
        if x < 88
           servopos := 137 - x
        elseif x > 87
           servopos := 50
    Pub Addtoservoangle
        if ~x > - 88
           servopos := 137 + ||x
        elseif x < - 87
           servopos := 225
    PUB Read8BitData | count,xtemp,ytemp
           count := 1
           xtemp := 0
           ytemp := 0
           repeat until count == 11
             count++
             xtemp := xtemp + SPI.read(SPI#XOUT8)                   'repeat for X-axis
             ytemp := ytemp + SPI.read(SPI#YOUT8)                   'repeat for Y-axis
           x := xtemp / 10
           x := ~x
    PUB Showdata
        DEBUG.Position(20,10)
        debug.str(string("X= "))
        DEBUG.clearend
        debug.dec(x)
        DEBUG.Position(20,12)
        DEBUG.clearend
        debug.str(string("Y= "))
        debug.dec(~y)
        DEBUG.Position(20,14)
        DEBUG.clearend
        debug.str(string("servopos= "))
        debug.dec(servopos)
    edited 2010-06-03 17:53
    What's a "Servocontrol"?
    edited 2010-06-03 18:18
    I believe hover is correct, based on your description of behavior it is likely not enough time is initally added to the timer count value to capture the first event. When this happens the timer must rollover which would account for the initial delay you're experiencing
    Paul Baker
    edited 2010-06-03 18:27
    Servo control is my changed version of Single Servo Spin
    CON
      _xinfreq=5_000_000
      _clkmode=xtal1+pll16x                 'The system clock is set at 80MHz (this is recommended for optimal resolution)
    VAR
      long position                         'The assembly program will read this variable from the main RAM to determine the
                                            ' servo signal's high pulse duration
      long Stack                         'Alot some stack space for the cog running MoveMotor to use
    PUB Init
      cognew(MoveMotor(1),@Stack)           'Start a new cog and run the MoveMotor method on it that outputs pulses on Pin 7
    pub tester
      'The new cog that is started above continuously reads the "position" variable as it's changed by the example Spin code below
      repeat
        position:=50                     'Start sending 1ms servo signal high pulses (100 * 10us = 1ms)
        waitcnt(clkfreq+cnt)                'Wait for 1 second (1ms high pulses continue to be generated by the other cog)
        position:=225                   'Start sending 1.38ms servo signal high pulses (Center position)
        waitcnt(clkfreq+cnt)                'Wait for 1 second (1.38ms high pulses continue to be generated by the other cog)
    PUB getposition(pos)
        position:=pos
        return
    PUB MoveMotor(Pin)                              'This method outputs a continuous stream of servo signal pulses on "Pin"
      dira[noparse][[/noparse]Pin]~~                                   'Set the direction of "Pin" to be an output
      repeat                                        'Send out a continous train of pulses
        outa[noparse][[/noparse]Pin]~~                                 'Set "Pin" High
        waitcnt((clkfreq/100_000)*position+cnt)     'Wait for the specifed position (units = 10 microseconds)
        outa[noparse][[/noparse]Pin]~                                  'Set "Pin" Low
        waitcnt(clkfreq/100+cnt)                    'Wait 10ms between pulses
    edited 2010-06-03 18:40
    Your listing shows that MoveMotor is being started using a value of 1 for the pin number although the comment says pin 7. The delay you're seeing is because the position variable is initially zero and the waitcnt in MoveMotor will hang up for about 50 seconds per repeat loop until the position variable is changed to some non-zero value. You might initialize it in Init just before you call cognew and that will eliminate the hang up. Alternatively, you could set a minimum position value of maybe 100us which servos will ignore anyway because it's too short. Try this:
    waitcnt((clkfreq/100_000)*(position#>10)+cnt)
    edited 2010-06-03 18:48
    That nailed it! Geeez. How do you guys keep all this in your heads?
    edited 2010-06-03 18:50
    "Debug" should be sarted:
    PUB start(rxpin, txpin, mode, baudrate)
    Your missing you pins and mode.
    Jim
    Thomas,
    It's a matter of learning to think logically, paying attention to details, and trying to forget all those things that we all know have to be a certain way. The most difficult part is the last one.
