My puppy linux startup time: 2 minutes?!?!
I have TRIED to switch to Linux, just TRIED. The only linux that I have gotten to work right on my system is Puppy linux. I have tried to use it as my OS, but it has 0 advantages. The biggest of which is the startup time. It says "5 second usual boot", then goes into a 2 minute long booting process (probably longer) that takes longer to boot then Windows XP!! I'm running it off a disk, so I may just have a slow drive, but I've booted it several times and each time it claims a faster boot, but with no avial. Any help here???
Micro
Check out my new website!!
Use the Propeller icon!!
Follow me on Twitter! Search "Microcontrolled"
Micro
CD or DVD?
The last time I used Puppy Linux I had a few problems with it.
The Linux I use the most is MEPIS It will run as a live CD
www.mepis.org/
The X windows server and video card drivers are the bane of Linux users. If I recall correctly Puppy can fall back to a non hardware accelerated driver which is why it is so compatible. Same is true for DSL and Knopix. You might want to find out what chipset you PC is using for video and see if it is on the compatible list. Intel and Nvidia usually are, ATI is spotty but getting better, and SiS is a basket case.
I'm curious why the only Linux you've gotten to work right is Puppy. What are your computer specs?
90 * 2 = Pi
Bob mentioned Mepis which has always been one of my favorites and a good solid Linux, then I was using Ubuntu seriously as it has the most support, and now a flavor of Ubuntu called Mint which is a sheer delight to use.
So Micro, what version Puppy have you installed (I hope) and what's the platform it's running on?
*Peter*
