SMT Solder video for UPEW: Tech test — Parallax Forums
RaymanRayman Posts: 15,422
edited 2010-07-01 00:01 in Propeller 1
Just did a little test to see if my somewhat primitive A/V capabilites are good enough to make good enough video for a little SMT soldering presentation at UPEW...
Soldered an 0805 resistor & capacitor on an obsolete board and it came out not too bad actually...
Here's a low quality (all I can upload here) clip:
Later on, I'll try to have a script and less caffeine [noparse]:)[/noparse]
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • hover1hover1 Posts: 1,929
    edited 2010-05-30 19:01
    A motion picture is worth 10,000 words!
    Caffeine: I usually don't try to solder untill after 10:AM, (4 hours after Starbucks). tongue.gif
    Jim
    Excellent! You make it look easy.
    Prep for this skipping coffee for at least 5 hours prior? [noparse];)[/noparse]
    OBC
    Propeller Feature Projects: PropellerPowered.com
    Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
  • P!-RoP!-Ro Posts: 1,189
    edited 2010-05-30 20:10
    Interesting seeing how you do it. It's definitely much different than the way I do it when working for a guy here in my town. He builds 3-D printers to sell on Ebay so he has to streamline everything. Instead of using a soldering iron we use a plastic cover with holes for the pads, and solder paste is smeared over the top. Then we place the parts and put the board on a stove to melt it. Either way it's no easy task!
    90 * 2 = Pi
  • RaymanRayman Posts: 15,422
    edited 2010-05-30 20:52
    Yes, for volume production, I use a laser-cut solder mask and solder paste, place parts, and then bake.
    But, for prototyping it's much faster and cheaper to do it this way!
    Plus, if you want to change out a component and try a different one, it's much easier to use an iron than an oven...
  • JonnyMacJonnyMac Posts: 9,401
    edited 2010-05-30 21:08
    Have you tried with a bit of flux on the pads, Ray? I've found -- on the few boards that I've done -- that it help me. My next N&V project will be a surface mount board, so I need to start practicing.
    Jon McPhalen
    Hollywood, CA
    edited 2010-05-30 21:49
    I never use flux anymore... But, if I did, it'd be the "no clean" variety...
    If you have dirty or old oxidized parts, then you need extra flux...
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2010-05-31 13:19
    Rayman, I heard two requests for such a presentation at UPEC. This would be well-received.
    We've got a new place at Parallax in the main room for these presentations, complete with a high-lumen projector and any kind of input source you may imagine.
    Be sure you get on OBC's list if you have not already done so.
    Parallax Inc.
    Follow me at http://twitter.com/ParallaxKen for some insider news.
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2010-06-30 23:21
    My technique is similar, except that I use flux, and don't put solder on the first pad. Instead, I just hold the part in place, and touch the iron tip to the joint. There is usually just enough solder on a lightly tinned iron that with the flux on the pad, it will slightly tack the part and hold it in place. There really won't be a "joint", just a little solder in the crease between the pad & part. Then solder the opposite side as normal, then the tacked side.
    I've found this to be a lot easier than placing a blob on the pad. The blob would always cause me problems with seating the part.
    I made the point in my UPEW SMT soldering presentation that everybody has their own style... But, it's still useful to see how other people do it...
    I hope to have time soon to post the presentation as a video somewhere. Several people at the expo asked about this...
    I should have made the point that for volume production, I use a solder paste, a stencil, and an oven; a totally different technique than the presentation. The hand soldering shown in the presentation is what I use for prototyping and maybe repair...
    My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
    My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
