PIR Power
·This is the first time I have worked with a PIR. I have played around with Basic Stamps for a number of years on and off. I have used most of the other sensors without problem but with the PIR I cannot get it to work correctly. I saw in another post that made reference to Google search·and I followed that and from what I read is that there might be a problem with noise and that a seperate power source is needed to make it work? I have never had this problem with other sensors. Is this something that is required to use the PIR a seperate power supply?
· The PIR stays High and if I put the Pin Low at start up then it stays Low? Any suggestions would be appreciated.
