Product Spec. for outdoor GPS sensor cover — Parallax Forums
kf4ixmkf4ixm Posts: 529
edited 2010-05-26 22:51 in General Discussion
Hi all, i know alot of members here have done some prototyping with plastics before and i'm looking for some information for a gps dome cover that i can have made somewhere in small quantities, well just one to start with, more later if my·RTU sells. [noparse]:)[/noparse]
Here are my requirements:
  • It has to be weather and U/V resistant
  • As transparent as possible to GPS signals
  • It has to be as strong as possible to withstand vandalism, animal curiosity as these units will be in remote areas.
  • Be around 4-6" in diameter, 4-6" tall, prefer measurements to be same tall as wide (inside measurements).
  • A half to one inch mounting flange around bottom, reinforced, moulded in gussets on outside between flange and side of dome preferred.
I prefer the thicker the better as long as gps signal attenuation is less that 1db, a couple at most.
Does anyone here do stuff like this, or, can anyone suggest someone that will do a prototype then small volume?
Any and all suggestions are greatly appreciated
  • stamptrolstamptrol Posts: 1,731
    edited 2010-05-26 14:18
    For small quantities, you'll probably have to be content with something off the shelf. Have a look at PVC electrical boxes. Easy to work with, seal very tight and are inexpensive. You can use a standard octagon box (about 4" across and 2" high) or go with a 4" x 4" or larger size. See your local electrical part distributor.
    Probably too far into the project, but Garmin makes a complete GPS unit in a round package (3" diameter x 0.75" thick) for less than $100 that is totally encapsulated and made for outdoor installation. One small cable powers the unit (12 volts) and brings the NMEA serial data out.
    Cheers,
    Tom Sisk
    http://www.siskconsult.com
    edited 2010-05-26 14:48
    My CNC is currently broken but if you are not in a hurry I can make a ABS enclosure like that in about 2 weeks after I fix it. ABS is very strong and UV resistant but I can't provide any waranties because I have not had time or a place to run weather testing.
    If you want something guaranteed your best bet would be and electrical wholesaler or home hardware. if you show up in coveralls the wholesalers never ask questions(well i had to show my license once).
    Lots of propeller based products in stock at affordable prices.
  • W9GFOW9GFO Posts: 4,010
    edited 2010-05-26 17:35
    Sounds like a perfect application for thermoforming. Sign shops typically have thermo forming machines. If you can make a wooden plug they should be able to make the domes for you. If not, it is not difficult to do at home. All you need is a wooden box, a vacuum, a metal frame and your oven. ABS is easy and forgiving to work with, polycarbonate (Lexan) is much stronger and durable but easier to mess up. Stay away from acrylic (Plexiglass), it cracks too easily.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
  • kf4ixmkf4ixm Posts: 529
    edited 2010-05-26 20:11
    Thanks all for the input!
    @stamptrol
    i had thought about a 3rd party gps early on, but it goes against my number one priority for this, to use all Parallax products in the design as this will be propeller powered and a parallax gps module.
    @mctrivia
    I am going to be putting together either an autocad or google sketchup of my design tonight or within the next few days. i already have rough pen sketches on paper, but would rather get it in electronic form to show you exactly what im looking for first. I plan on the dome to be 3/8" thick all the way around, including outside flange. Outside finished dimentions of 6 3/4" x 6 3/4", with a one inch flange on outer bottom, making the total flange outside dimention of 8 3/4". this should give me an inside diameter of 6" wide x 6" tall at the tallest point of the dome. 1/4" thick gussets from outer edge of flange up 45 deg. to the dome, 6 of them spaced at 60 degree centers and 6 3/8" mounting holes between gussets also spaced at 60 degree intravals. [noparse]:)[/noparse] like i said, i'll get a drawing together soon!
    @W9GFO
    i have looked into some thermoplastic fabrication companies on the web today, some offer prototyping and small quantity runs.
    I have about (about) decided ABS (something white or light cream color) is the way to go with this for weather resistance and uv durability. i have even kicked around the idea of carbonfiber, but i haven't researched much about how feasable this would be compared to abs. As stated above, everything in this rtu will be from parallax, except for the dome and ip67 box (probably a hoffman)·for the electronics and mounting hardware. I even plan on plastering a big "powered by Propeller" sticker on the front of it! [noparse]:D[/noparse]
    Thanks for all the input, and if anyone else has any input, im all ears!
    Post Edited (kf4ixm) : 5/26/2010 8:16:01 PM GMT
    edited 2010-05-26 20:15
    kf4ixm that is unfortunetly bigger then i can make. I plan to build a bigger cnc some day but money and space is tight.
    edited 2010-05-26 20:22
    @mctrivia
    Thats ok, thanks for the offer anyway!
    edited 2010-05-26 21:11
    For something that's ready-made, you might consider giving Ritchie Navigation a call. Their replacement compass domes are tough and inexpensive, and they come in a variety of sizes. The domed housings for outdoor CCTV cameras are another potential source.
    edited 2010-05-26 21:51
    Carbon fiber is conductive, I don't think that would work too well with GPS. You can however get ABS with a carbon fiber design printed on it, then thermo form it into a dome.
    Rich H
    Ok, i was wondering about carbon fiber being conductive W9GFO, thanks for confiming that for me. i was just thinking about it for strength reasons only. i believe abs will be the way to go. Thanks!
