Product Spec. for outdoor GPS sensor cover
Hi all, i know alot of members here have done some prototyping with plastics before and i'm looking for some information for a gps dome cover that i can have made somewhere in small quantities, well just one to start with, more later if my·RTU sells. [noparse]:)[/noparse]
Here are my requirements:
I prefer the thicker the better as long as gps signal attenuation is less that 1db, a couple at most.
Does anyone here do stuff like this, or, can anyone suggest someone that will do a prototype then small volume?
Any and all suggestions are greatly appreciated
- It has to be weather and U/V resistant
- As transparent as possible to GPS signals
- It has to be as strong as possible to withstand vandalism, animal curiosity as these units will be in remote areas.
- Be around 4-6" in diameter, 4-6" tall, prefer measurements to be same tall as wide (inside measurements).
- A half to one inch mounting flange around bottom, reinforced, moulded in gussets on outside between flange and side of dome preferred.
Probably too far into the project, but Garmin makes a complete GPS unit in a round package (3" diameter x 0.75" thick) for less than $100 that is totally encapsulated and made for outdoor installation. One small cable powers the unit (12 volts) and brings the NMEA serial data out.
Cheers,
Tom Sisk
http://www.siskconsult.com
If you want something guaranteed your best bet would be and electrical wholesaler or home hardware. if you show up in coveralls the wholesalers never ask questions(well i had to show my license once).
Lots of propeller based products in stock at affordable prices.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
@stamptrol
i had thought about a 3rd party gps early on, but it goes against my number one priority for this, to use all Parallax products in the design as this will be propeller powered and a parallax gps module.
@mctrivia
I am going to be putting together either an autocad or google sketchup of my design tonight or within the next few days. i already have rough pen sketches on paper, but would rather get it in electronic form to show you exactly what im looking for first. I plan on the dome to be 3/8" thick all the way around, including outside flange. Outside finished dimentions of 6 3/4" x 6 3/4", with a one inch flange on outer bottom, making the total flange outside dimention of 8 3/4". this should give me an inside diameter of 6" wide x 6" tall at the tallest point of the dome. 1/4" thick gussets from outer edge of flange up 45 deg. to the dome, 6 of them spaced at 60 degree centers and 6 3/8" mounting holes between gussets also spaced at 60 degree intravals. [noparse]:)[/noparse] like i said, i'll get a drawing together soon!
@W9GFO
i have looked into some thermoplastic fabrication companies on the web today, some offer prototyping and small quantity runs.
I have about (about) decided ABS (something white or light cream color) is the way to go with this for weather resistance and uv durability. i have even kicked around the idea of carbonfiber, but i haven't researched much about how feasable this would be compared to abs. As stated above, everything in this rtu will be from parallax, except for the dome and ip67 box (probably a hoffman)·for the electronics and mounting hardware. I even plan on plastering a big "powered by Propeller" sticker on the front of it! [noparse]:D[/noparse]
Thanks for all the input, and if anyone else has any input, im all ears!
Post Edited (kf4ixm) : 5/26/2010 8:16:01 PM GMT
Thats ok, thanks for the offer anyway!
Rich H
