Ethernet and SD card on same SPI buss?
I want to connect the Prop to an SD card and ENC28J60. Instead of using 8 I/O's, I'm thinking it would be better to share the Clk, Do, and Di - This should only take 5 I/O;
But I'm an SPI beginner and want to understand a few things before I prototype it - I bet someone out there can help;
1 - Should I put Pull-ups on Clk, Do, Di, Chip_Select_SD, and Chip_Select_ENC?
2 - When it comes to flow control, do need to stop PropTCP before starting fsrw & vice versa?
Or is it a better idea just to use 8 I/O?
Schematic is attached, if it helps.
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
I would put pullup on the /CSs for when the Prop goes "tri-state"
Style and grace : Nil point
Surely one can use a spin lock for mutual exclusive hardware access in the drivers.
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
I tried to do this in one of my projects a while back. The idea was to be able to stream WAV files from an SD card while doing an occasional NTP (network time protocol) request. I think there's a previous topic that I started here in the forums that outlined my approach. My idea was to usual mutual exclusion (SD card code would hold a lock when fetching a block, ethernet code would hold a lock when talking to the ENC28J60; no two cogs would both try to use the same set of pins at the same time). Never could get it working, although I didn't put a whole lot of effort into it. I ended up abandoning the idea in favor of using an IO Expander to free up some other devices (mostly buttons and status LEDs) from the prop's IO pins, making room for the SD card and ethernet nic.
Here was the original thread:
http://forums.parallax.com/forums/default.aspx?f=25&m=326455
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Then I'd do it flexible. Some jumpers for the DI/DO/CLK so you can connect it to the same or to different pins. Because using one SPI bus simply limits the transfer speed. And if this is fine very much depends on the project. In some it's OK in others you don't want to share bandwidth.
If it's for a concrete project you know (or should be able to estimate) what transfer speeds are needed for which device and of course can hardwire one version as the needs tell you.
SD cards aren't fully SPI compliant, they leave DO asserted even after CS has gone high as Rayman said. However if you send a few (16 or so I think) clocks to the card after the CS goes high the card will release DO. If you look at most of the recent SPI block code versions for SD card there is a comment in them about "Cluso99 wanted this mod to tristate the SD card", make sure that set of code is uncommented as that will do what you're after because the RamBlade/TriBlade use the SD pins to do parallel RAM access as well.
Nathan
"Free as in freedom, beer gratefully accepted though."
Eventually it's possible to share the 2 devices at the same 4 pins with the circuit of the second picture.
The idea is that the inactive device gets a lot of CS pulses, but no CLOCK puls and will therefore not receive or send anything.
Andy
I hope so..
K.
I always have someone watching my back.
NO
NO
NO
NO
NO!!!
... Need to make this clear but you would need to rewrite the drivers to make them support this kind of setup. If you feel like making the hardware like that then be prepared to rewrite the drivers for the FSRW and the ethernet adapter.
Additionally there will be a pretty significant speed drop. Probably over half. Depending how you have the locks setup.
Nyamekye,
@kye - tell me how you really feel
It sounds like the best approach for me is to use 2 SPI busses. In exchange for 3 I/O, I get faster throughput and an easier interface. Done!
Ha, finals have ended for me.
Rewriting the drivers are a problem because the propeller platform should be able to use the standard drvers available online in the obex. Having to mess with the code is not good.
I'm thinking about what's best for Nick's platform.
@ Nick
I received your package.
No RTC however with it =(.
Thanks!
Nyamekye,
Like I said. It's fine for the average user. People will do what makes sense to them for their situation.
That's why I used your proposed design over two years ago. BTW: Keep up your good work.
I suppose you have to wait for the write to complete to keep the user from pulling the card prematurely. It is most likely possible instead to provide an asynchronous notification that the write is done.
When PropII, TurboProp, or whatever it's called arrives, pin availability will be less of an issue. I wonder if we'll live long enough to see that.
The SD is a very particular device. You can bus-share it with some things, but I've worked with it and the ENC28J60 and it's my opinion that getting the two things to play together on the same bus is going to be very hard and not work very well no matter what.
It is truly beyond me why dis-engaging the SD device driver to do other things, then re-engaging it for a status poll would somehow cause a failure. Nevertheless, since you have put serious time in it and I have no reason to doubt that, you accumulate substantial credibility. So I'll accept that.
Cheers [noparse]:)[/noparse]
It's a problem because the ethernet chip is timing critical; it only has memory to cache a few packets and packets can arrive pretty quickly on a local 10baseT ethernet and you don't have control of the timing of incoming packets. It's just a bad combination with another block-hoggy device of any sort, but particularly one that is as finicky as a SD card.
On the plus side though, it has to be admitted that you could probably share a single SPI engine and cog with both devices, since you can't use both at the same time at all. IF you could make it work...
Mikronauts new uSD/Ethernet module has four pins for each device, precisely because you don't want to try to share an SPI bus between Ethernet and uSD. I expect the final prototype to be in my hands in about two weeks [noparse]:)[/noparse] (yep, another Sapieha work of art) - the initial version worked great with Harrison's stack and fsrw. I won't say more for now... and I don't want to hijack Nick's thread.
On PropCade I do share an SPI bus between SPI ram's, an MCP23S17 IO extender, and a uSD socket - however I expect to complete a uSD transaction, release /CS, and send extra clocks to make sure SO is released.
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
Las - Large model assembler Largos - upcoming nano operating system
Post Edited (Bill Henning) : 5/25/2010 12:54:47 AM GMT
I was surfing Digikey today and I thought I seen a I2C to SPI converter IC. This may help. Ill see if I cant find that data sheet tomorrow.
* Edited - check out the data sheet It may be an answer
www.nxp.com/documents/data_sheet/SC18IS602_602B_603.pdf
This would mean that no extra pins would be needed and the I2C driver in the obex could be used.
Post Edited (Zap-o) : 5/25/2010 2:37:35 AM GMT
I think it's agreed that using both devices on the same buss at the same time is challenging. Something I might do if I had a single design in mind or if I needed the pins, but probably not otherwise.
@bill - Your board sounds really cool! I've been playing with a similiar proto & I've been thinking of doing a webserver (grabbing files from the sd card). Will you have something to show off @ UPEW?
Yes, I will be bringing it to UPEW... the board is approx. 1.35"x2.50", fits standard 10 pin (+3.3,GND, Pn..Pn+7) connectors - with four pins for the ENC28J60, and four pins for a uSD socket. Harrison's driver works great on an earlier version, and so does fsrw on the uSD side [noparse]:)[/noparse]
As usual, Sapieha made a layout that looks like a work of art!
It should plug right into Jon's platform... SpinStudio... Parallax ProtoBoard's... bread board... my boards [noparse]:)[/noparse] ... any board can become an instant Propeller based webserver!
Once I have tested the final prototypes (I should have them in approx. 2 weeks) I will post pics and order a production run. Initial versions have been working for months.
