433 MHz RF Transceiver
Has anyone seen an Object to send and receive data using the 433 MHz RF Transceiver?
I would like to use this transceiver in a Stingray project. I am modeling it after 'CoolBot' and need to be able to remotely send a series of string characters to the Stingray.
Tie together the TX and RX lines, installing a 1k resistor at the TX line.
TX RX | | / | \ | \ | / | | | |-------- | SIO (on TRX)MacGeek117
BS2: $49
SX48 Protoboard: $10
Propeller Protoboard: Priceless
www.apple.com
www.parallax.com
www.goldmine-elec.com
www.expresspcb.com
www.jameco.com
Thank you, but that object is too unstable, from what I have read.
SEL
·http://forums.parallax.com/showthread.php?p=852197
I don't know if there was·a resolution, but I remember·the thread.
Jim
Post Edited (hover1) : 5/24/2010 9:52:06 PM GMT
I took a look, but it's not going to work for me. I was hoping to find an Object that I could use out of the box, so to speak.
Thanks for your thoughts and time.
Best regards,
SEL
I think someone translated the existing BS2 code for this transceiver into Spin for the Propeller. I don't think it was ever put into the Object Exchange because it wasn't finished up. I suggest you browse the Propeller forum for related threads. Beau may have done it.
Thank you very much. I will do as you have suggested. Also I'll try to contact Beau.
Best regards,
SEL
