Platform VGA-AV Board — Parallax Forums
Brian RileyBrian Riley Posts: 626
edited 2010-05-23 18:29 in Propeller 1
A new Gadget Gangster Platform based board containing VGA (P16..23), TV (P12..14/15), Mono Sound (P11), and PS2 Keyboard (P26..27) and Mouse (24..25). It also has a modest Prototyping area with access to P0..10.
Standard Platform "short board" (2.8" x 2.5") form factor. VGA is standard HD15 female, 2 6 pin mini-DIN PS2 connectors for KBD and MSE. TV and sound brought out to an "AV" connector (3.5mm stereo jack) in same fashion as "Propeller Backpack" (NTSC video to "tip", sound to first "ring", ground to second "ring")
Pictures here of the prototype. Board will go fabrication Monday 5/24/10 and expect them to be ready for sale between 6/9 and 6/15. Current plans are $10 (+ S/H) for bare PCB and $17 (+ S/H) for complete kit (19 resistors, 2 caps, 2 PS2 connectors, AV connector, VGA connector, and Platform mounting headers.
There will be more info on my website in thee next week or so
www.wulfden.org/TheShoppe/prop/
There's a few more pix of the board 'in action' ... MandelBrot display in PropBasic on NTSC video, The classic Graphics Demo with KBD and MSE, and another PropBasic VGA demo.
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/prop/ - Propeller Products
www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
  • wjsteelewjsteele Posts: 697
    edited 2010-05-23 12:13
    Cool board. One question... on your prototype you have through hole plating. Did you have someone do that for you when they built the prototype board or did you do that? In other words, do you know how a home hobbiest can do that?
    Bill
  • Brian RileyBrian Riley Posts: 626
    edited 2010-05-23 18:16
    wjsteele said...
    Bill
    My proto board was done via ExpressPCB "mini-board" service ($61/3 boards).
    I must confess I haven't the foggiest idea how to do it myself!
    cheers ... BBR
  • LeonLeon Posts: 7,620
    Through-hole plating can be done at home, kits are available. It isn't easy, though.
    Leon Heller
    Amateur radio callsign: G1HSM
