BST error report list — Parallax Forums
T ChapT Chap Posts: 4,249
edited 2010-05-23 03:15 in Propeller 1
I recently started seeing these reports, probably checked a setting to display them. The system runs fine so is there any reason to try to fix these errors?
  • BradCBradC Posts: 2,601
    edited 2010-05-23 02:32
    You can disable them in Tools->Compiler Preferences->Options.
    You can also selectively disable each warning by starting a comment on the line in question with '!W
    If things run as they should then I'd not worry about them. Some of my projects spew stacks of warnings and info messages.
    "Are you suggesting coconuts migrate?"
  • T ChapT Chap Posts: 4,249
    Thanks BradC
