Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
BST error report list — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Propeller 1
T Chap
4,260
2010-05-22 22:28
edited 2010-05-23 03:15
in
Propeller 1
I recently started seeing these reports, probably checked a setting to display them. The system runs fine so is there any reason to try to fix these errors?
476 x 143
23K
23.2K
BradC
2,601
2010-05-23 02:32
edited 2010-05-23 02:32
You can disable them in Tools->Compiler Preferences->Options.
You can also selectively disable each warning by starting a comment on the line in question with '!W
If things run as they should then I'd not worry about them. Some of my projects spew stacks of warnings and info messages.
"Are you suggesting coconuts migrate?"
T Chap
4,260
2010-05-23 03:15
Thanks BradC
Sign In
Register
to comment.
