boe bot sensors
·I have had my boe bot for a while now and i can not get any of the sensors to work except for the wisker sensor. can you tell me what i am doing wrong?·
Without code and a look at your hardware setup, no-one will be able to tell you much that's helpful. Why don't you pick out one sensor, set it up as the book tells you to, and run the corresponding program from the book, and then if it doesn't work, tell us what happened?
- Stephen
