·I have had my boe bot for a while now and i can not get any of the sensors to work except for the wisker sensor. can you tell me what i am doing wrong? ·
You'd probably get better answers if you concentrated on one sensor at a time, and if you told us what is and is not working.
Without code and a look at your hardware setup, no-one will be able to tell you much that's helpful. Why don't you pick out one sensor, set it up as the book tells you to, and run the corresponding program from the book, and then if it doesn't work, tell us what happened?
If you have the manual start at the begining and work through it. If you don't have it you can download it from the Parallax site for free. If you have trouble with a sensor show us your code, your connections and what you expect to happen and what does happen. Then ask ONE question at a time until you get that function working.
- Stephen
