Using Objects FSRW and GPS_Float to make a Google Earth .kml file
I am trying to Use the objects FSRW and GPS_Float to make a Google Earth .kml file,
but I am having trouble writing the real numbers Float_Longitude_Deg and Float_Latitude_Deg
to the file on the sd card.
I believe the problem is at
sdcard.sdstr(gps.Float_Longitude_Deg)
sdcard.sdstr(string(","))
sdcard.sdstr(gps.Float_Latitude_Deg)
sdcard.sdstr(string("155"))
sdcard.sdstr(string(13,10))
It writes
0,0,155
0,0,155
0,0,155
to the file.
I am sure this has been discussed before, but I can't find a thread with search.
The file created
It writes
0,0,155
0,0,155
0,0,155
to the file.
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
obj
sdcard: "fsrw"
gps: "GPS_Float"
var
long start
pub main
sdcard.mount(3)
sdcard.popen(string("text.kml"),"w")
if gps.init
sdcard.SDStr(string("<?xml version='1.0' encoding='UTF-8'?>",13,10))
sdcard.SDStr(string("<kml xmlns='http://www.opengis.net/kml/2.2'>",13,10))
sdcard.SDStr(string(" <Document>",13,10))
sdcard.SDStr(string(" <name>Paths</name>",13,10))
sdcard.SDStr(string("<description>This is a test run of collecting GPS data</description>",13,10))
sdcard.SDStr(string("<Style id='yellowLineGreenPoly'>",13,10))
sdcard.SDStr(string(" <LineStyle>",13,10))
sdcard.SDStr(string(" <color>7f00ffff</color>",13,10))
sdcard.SDStr(string(" <width>4</width>",13,10))
sdcard.SDStr(string(" </LineStyle>",13,10))
sdcard.SDStr(string(" <PolyStyle>",13,10))
sdcard.SDStr(string(" <color>7f00ff00</color>",13,10))
sdcard.SDStr(string(" </PolyStyle>",13,10))
sdcard.SDStr(string(" </Style>",13,10))
sdcard.SDStr(string(" <Placemark>",13,10))
sdcard.SDStr(string(" <name>Absolute Extruded</name>",13,10))
sdcard.SDStr(string(" <description>Transparent green wall with yellow outlines</description>",13,10))
sdcard.SDStr(string(" <styleUrl>#yellowLineGreenPoly</styleUrl>",13,10))
sdcard.SDStr(string(" <LineString>",13,10))
sdcard.SDStr(string(" <extrude>1</extrude>",13,10))
sdcard.SDStr(string(" <tessellate>1</tessellate>",13,10))
sdcard.SDStr(string(" <altitudeMode>absolute</altitudeMode>",13,10))
sdcard.SDStr(string("<coordinates>"))
repeat 10000
sdcard.SDStr(string("</coordinates>",13,10))
sdcard.SDStr(string(" </LineString>",13,10))
sdcard.SDStr(string(" </Placemark>",13,10))
sdcard.SDStr(string(" </Document>",13,10))
sdcard.SDStr(string("</kml>",13,10))
else
sdcard.SDStr(string("GPS failed to start",13,10))
sdcard.pclose
Lightblink
Pub Lightblink
dira~~
repeat 9
!outa
waitcnt(9_000_000 + cnt)
The file created
<Document>
<name>Paths</name>
<LineStyle>
<width>4</width>
</LineStyle>
<PolyStyle>
</PolyStyle>
</Style>
<Placemark>
<LineString>
<coordinates>0,0,155
0,0,155
0,0,155
0,0,155
.......many more
</coordinates>
</LineString>
</Placemark>
</Document>
</kml>
Also looking at GPS_Float_Demo I needed to add the object FloatString to convert the float number to string.
http://forums.parallax.com/showthread.php?p=729953
Andrew Williams
WBA Consulting
My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
sdcard.SDStr(string("<coordinates>"))have a CR LF sequence ???? like this
sdcard.SDStr(string("<coordinates>"),13,10)cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
www.wulfden.org/TheShoppe/prop/ - Propeller Products
www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
Andrew Williams
WBA Consulting
time saving a different track into one of ten files.
Disappointed that I am already out of cogs. I was hoping to add some sensors to the mix.
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 obj sdcard: "fsrw" gps : "GPS_Float" DEBUG : "Parallax Serial Terminal" FS : "FloatString" F : "Float32Full" var long lat1, long1, longavg, latavg long x, filenum, open long Stack[noparse][[/noparse]16], buttonpressed pub main dira[noparse][[/noparse]16]~~ sdcard.mount(3) 'DEBUG.start(57600) gps.init initButton filenum := 1 open := 0 repeat repeat while buttonpressed == 0 shortblink buttonpressed := 0 if open == 1 Endfile else Openfile Pub Openfile case filenum 1: sdcard.popen(string("track1.kml"),"w") 2: sdcard.popen(string("track2.kml"),"w") 3: sdcard.popen(string("track3.kml"),"w") 4: sdcard.popen(string("track4.kml"),"w") 5: sdcard.popen(string("track5.kml"),"w") 6: sdcard.popen(string("track6.kml"),"w") 7: sdcard.popen(string("track7.kml"),"w") 8: sdcard.popen(string("track8.kml"),"w") 9: sdcard.popen(string("track9.kml"),"w") 10: sdcard.popen(string("track10.kml"),"w") 'term1 WriteFileHeader filenum++ open := 1 CheckSatFix WriteLineCoors Pub EndFile sdcard.SDStr(string(" </LineString>",13,10)) sdcard.SDStr(string(" </Placemark>",13,10)) sdcard.SDStr(string(" </Document>",13,10)) sdcard.SDStr(string("</kml>",13,10)) sdcard.pclose open := 0 PUB InitButton cognew(button(@buttonpressed), @stack) Pub button(bp) dira~ long[noparse][[/noparse]bp] := 0 repeat if ina == 1 long[noparse][[/noparse]bp] := 1 Pub CheckSatFix repeat while gps.Long_Fix_Quality < 1 or gps.Long_Fix_Quality > 8 FixIndicatoroff FixIndicatorOn Pub FixIndicatorOn outa[noparse][[/noparse]16] := 1 Pub FixIndicatorOff outa[noparse][[/noparse]16] := 0 Pub WriteFileHeader sdcard.SDStr(string("<?xml version='1.0' encoding='UTF-8'?>",13,10)) sdcard.SDStr(string("<kml xmlns='http://www.opengis.net/kml/2.2'>",13,10)) sdcard.SDStr(string(" <Document>",13,10)) sdcard.SDStr(string(" <name>Paths</name>",13,10)) sdcard.SDStr(string("<description>This track was started on ")) sdcard.sddec(gps.Long_Month) sdcard.SDStr(string("/")) sdcard.sddec(gps.Long_Day) sdcard.SDStr(string("/")) sdcard.sddec(gps.Long_year) sdcard.SDStr(string(" at ")) sdcard.sddec(gps.Long_Hour - 4) sdcard.SDStr(string("|")) sdcard.sddec(gps.Long_minute) sdcard.SDStr(string(".</description>",13,10)) sdcard.SDStr(string("<Style id='yellowLineGreenPoly'>",13,10)) sdcard.SDStr(string(" <LineStyle>",13,10)) sdcard.SDStr(string(" <color>7f00ffff</color>",13,10)) sdcard.SDStr(string(" <width>4</width>",13,10)) sdcard.SDStr(string(" </LineStyle>",13,10)) sdcard.SDStr(string(" <PolyStyle>",13,10)) sdcard.SDStr(string(" <color>7f00ff00</color>",13,10)) sdcard.SDStr(string(" </PolyStyle>",13,10)) sdcard.SDStr(string(" </Style>",13,10)) sdcard.SDStr(string(" <Placemark>",13,10)) sdcard.SDStr(string(" <name>Absolute Extruded</name>",13,10)) sdcard.SDStr(string(" <description>Transparent green wall with yellow outlines</description>",13,10)) sdcard.SDStr(string(" <styleUrl>#yellowLineGreenPoly</styleUrl>",13,10)) sdcard.SDStr(string(" <LineString>",13,10)) sdcard.SDStr(string(" <extrude>1</extrude>",13,10)) sdcard.SDStr(string(" <tessellate>1</tessellate>",13,10)) sdcard.SDStr(string(" <altitudeMode>absolute</altitudeMode>",13,10)) Pub WriteLineCoors sdcard.SDStr(string("<coordinates>")) x := 0 repeat while buttonpressed == 0 x++ CheckSatFix TakeReading 'term2 sdcard.sdstr(fs.floattostring(longavg)) sdcard.sdstr(string(",")) sdcard.sdstr(fs.floattostring(latavg)) sdcard.sdstr(string(",")) sdcard.sdstr(fs.floattostring(gps.Float_Altitude_Above_MSL)) sdcard.sdstr(string(13,10)) waitcnt (clkfreq * 4 + cnt) sdcard.SDStr(string("</coordinates>",13,10)) Pub ShortBlink repeat 8 !outa[noparse][[/noparse]16] waitcnt(9000_000 + cnt) PUB TakeReading latavg := gps.Float_Latitude_Deg longavg := gps.Float_Longitude_Deg { -======Not working. Locks up========- long1 := lat1 := 0.0 repeat 10 lat1 := f.fadd(lat1,gps.Float_Latitude_Deg) long1 := f.fadd(long1,gps.Float_Longitude_Deg) latavg := f.fdiv(lat1,10.0) longavg := f.fdiv(long1,10.0) } Pub Term1 DEBUG.Position(20,10) DEBUG.str(string("Fix Quality: ")) DEBUG.Position(20,12) DEBUG.str(string("Number of Sats: ")) DEBUG.Position(20,14) DEBUG.str(string("Reading Number: ")) DEBUG.Position(20,16) DEBUG.str(string("Long: ")) DEBUG.Position(20,18) DEBUG.str(string("Lat: ")) Pub Term2 DEBUG.Position(34,10) DEBUG.clearend DEBUG.dec(gps.Long_Fix_Quality) DEBUG.Position(37,12) DEBUG.clearend DEBUG.dec(gps.Long_SatID_In_Fix(0)) DEBUG.Position(37,14) DEBUG.clearend DEBUG.dec(x) DEBUG.Position(27,16) DEBUG.clearend DEBUG.str(fs.floattostring(longavg)) DEBUG.Position(27,18) DEBUG.clearend DEBUG.str(fs.floattostring(latavg))Check
obex.parallax.com/objects/579/
(only one cog, I haven't tested it yet)
and
obex.parallax.com/objects/225/
(2 cogs, the GPS parsing engine works very well)
Massimo
