Using Objects FSRW and GPS_Float to make a Google Earth .kml file — Parallax Forums
Thomas FletcherThomas Fletcher Posts: 91
edited 2010-05-21 11:51 in Propeller 1
I am trying to Use the objects FSRW and GPS_Float to make a Google Earth .kml file,
but I am having trouble writing the real numbers Float_Longitude_Deg and Float_Latitude_Deg
to the file on the sd card.
I believe the problem is at
sdcard.sdstr(gps.Float_Longitude_Deg)
sdcard.sdstr(string(","))
sdcard.sdstr(gps.Float_Latitude_Deg)
sdcard.sdstr(string("155"))
sdcard.sdstr(string(13,10))
It writes
0,0,155
0,0,155
0,0,155
to the file.
I am sure this has been discussed before, but I can't find a thread with search.
CON
  _CLKMODE = XTAL1 + PLL16X
  _XINFREQ = 5_000_000
obj
   sdcard: "fsrw"
      gps: "GPS_Float"
var
   long start
pub main
       sdcard.mount(3)
       sdcard.popen(string("text.kml"),"w")
       if gps.init
            sdcard.SDStr(string("<?xml version='1.0' encoding='UTF-8'?>",13,10))
            sdcard.SDStr(string("<kml xmlns='http://www.opengis.net/kml/2.2'>",13,10))
            sdcard.SDStr(string("  <Document>",13,10))
            sdcard.SDStr(string("    <name>Paths</name>",13,10))
            sdcard.SDStr(string("<description>This is a test run of collecting GPS data</description>",13,10))
            sdcard.SDStr(string("<Style id='yellowLineGreenPoly'>",13,10))
            sdcard.SDStr(string("      <LineStyle>",13,10))
            sdcard.SDStr(string("        <color>7f00ffff</color>",13,10))
            sdcard.SDStr(string("        <width>4</width>",13,10))
            sdcard.SDStr(string("      </LineStyle>",13,10))
            sdcard.SDStr(string("      <PolyStyle>",13,10))
            sdcard.SDStr(string("        <color>7f00ff00</color>",13,10))
            sdcard.SDStr(string("      </PolyStyle>",13,10))
            sdcard.SDStr(string("    </Style>",13,10))
            sdcard.SDStr(string("    <Placemark>",13,10))
            sdcard.SDStr(string("      <name>Absolute Extruded</name>",13,10))
            sdcard.SDStr(string("      <description>Transparent green wall with yellow outlines</description>",13,10))
            sdcard.SDStr(string("      <styleUrl>#yellowLineGreenPoly</styleUrl>",13,10))
            sdcard.SDStr(string("      <LineString>",13,10))
            sdcard.SDStr(string("        <extrude>1</extrude>",13,10))
            sdcard.SDStr(string("        <tessellate>1</tessellate>",13,10))
            sdcard.SDStr(string("        <altitudeMode>absolute</altitudeMode>",13,10))
            sdcard.SDStr(string("<coordinates>"))
            repeat 10000
           sdcard.SDStr(string("</coordinates>",13,10))
           sdcard.SDStr(string("      </LineString>",13,10))
           sdcard.SDStr(string("    </Placemark>",13,10))
           sdcard.SDStr(string("  </Document>",13,10))
           sdcard.SDStr(string("</kml>",13,10))
       else
           sdcard.SDStr(string("GPS failed to start",13,10))
       sdcard.pclose
       Lightblink
Pub Lightblink
       dira~~
       repeat 9
          !outa
          waitcnt(9_000_000 + cnt)
The file created
  <Document>
    <name>Paths</name>
      <LineStyle>
        <width>4</width>
      </LineStyle>
      <PolyStyle>
      </PolyStyle>
    </Style>
    <Placemark>
      <LineString>
<coordinates>0,0,155
0,0,155
0,0,155
0,0,155
.......many more
</coordinates>
      </LineString>
    </Placemark>
  </Document>
</kml>
  • Thomas FletcherThomas Fletcher Posts: 91
    edited 2010-05-19 15:18
    Turns out I had two mistakes. I made the receive and transmit pin for the GPS the same number.
    Also looking at GPS_Float_Demo I needed to add the object FloatString to convert the float number to string.
    edited 2010-05-19 16:28
    Here's a thread on the same topic you might want to look at. I started with a KML GPS logger to learn how to use the GPS for my Propeller based Reverse-GeoCache project.
    http://forums.parallax.com/showthread.php?p=729953
    Andrew Williams
    WBA Consulting
    WBA-TH1M Sensirion SHT11 Module
    My Prop projects: Reverse Geo-Cache Box, Custom Metronome, Micro Plunge Logger
    edited 2010-05-19 17:09
    Thank you!
    edited 2010-05-19 20:42
  • fixmaxfixmax Posts: 91
    edited 2010-05-19 20:56
    I think that is amazing! I actually am working on an application that would really benefit with that. Thanks for the pictures.
  • Brian RileyBrian Riley Posts: 626
    edited 2010-05-20 19:32
    Should not this line
    have a CR LF sequence ???? like this
                sdcard.SDStr(string("<coordinates>"),13,10)
    cheers ... BBR
    cheers ... brian riley, n1bq, underhill center, vermont
    The Shoppe at Wulfden
    www.wulfden.org/TheShoppe/
    www.wulfden.org/TheShoppe/prop/ - Propeller Products
    www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
    edited 2010-05-20 19:48
    It works both ways, as with basic HTML. An entire HTML page can be completely free of carriage returns because they are not part of the HTML format structure. They only exist for ease of reading and a browser doesn't care if they exist.
    Andrew Williams
    WBA Consulting
    edited 2010-05-21 00:06
    Current code. I have added a wait for Fix and a toggle button. Press button to open file and start recording. Again to close file. Each
    time saving a different track into one of ten files.
    Disappointed that I am already out of cogs. I was hoping to add some sensors to the mix.
    CON
    obj
       sdcard: "fsrw"
       gps   : "GPS_Float"
       DEBUG : "Parallax Serial Terminal"
       FS    : "FloatString"
       F     : "Float32Full"
    var
       long lat1, long1, longavg, latavg
       long x, filenum, open
       long Stack[noparse][[/noparse]16], buttonpressed
    pub main
           dira[noparse][[/noparse]16]~~
           sdcard.mount(3)
           'DEBUG.start(57600)
           gps.init
           initButton
           filenum := 1
           open := 0
           repeat
              repeat while buttonpressed == 0
              shortblink
              buttonpressed := 0
              if open == 1
                 Endfile
              else
                 Openfile
    Pub Openfile
              case filenum
                 1:   sdcard.popen(string("track1.kml"),"w")
                 2:   sdcard.popen(string("track2.kml"),"w")
                 3:   sdcard.popen(string("track3.kml"),"w")
                 4:   sdcard.popen(string("track4.kml"),"w")
                 5:   sdcard.popen(string("track5.kml"),"w")
                 6:   sdcard.popen(string("track6.kml"),"w")
                 7:   sdcard.popen(string("track7.kml"),"w")
                 8:   sdcard.popen(string("track8.kml"),"w")
                 9:   sdcard.popen(string("track9.kml"),"w")
                 10:  sdcard.popen(string("track10.kml"),"w")
              'term1
              WriteFileHeader
              filenum++
              open := 1
              CheckSatFix
              WriteLineCoors
    Pub EndFile
            sdcard.pclose
            open := 0
    PUB InitButton
       cognew(button(@buttonpressed), @stack)
    Pub button(bp)
       dira~
       long[noparse][[/noparse]bp] := 0
       repeat
         if ina == 1
            long[noparse][[/noparse]bp] := 1
    Pub CheckSatFix
        repeat while gps.Long_Fix_Quality < 1 or gps.Long_Fix_Quality > 8
           FixIndicatoroff
        FixIndicatorOn
    Pub FixIndicatorOn
        outa[noparse][[/noparse]16] := 1
    Pub FixIndicatorOff
        outa[noparse][[/noparse]16] := 0
    Pub WriteFileHeader
                sdcard.SDStr(string("<description>This track was started on "))
                sdcard.sddec(gps.Long_Month)
                sdcard.SDStr(string("/"))
                sdcard.sddec(gps.Long_Day)
                sdcard.sddec(gps.Long_year)
                sdcard.SDStr(string(" at "))
                sdcard.sddec(gps.Long_Hour - 4)
                sdcard.SDStr(string("|"))
                sdcard.sddec(gps.Long_minute)
                sdcard.SDStr(string(".</description>",13,10))
    Pub WriteLineCoors
                x := 0
                    x++
                    CheckSatFix
                    TakeReading
                    'term2
                    sdcard.sdstr(fs.floattostring(longavg))
                    sdcard.sdstr(fs.floattostring(latavg))
                    sdcard.sdstr(fs.floattostring(gps.Float_Altitude_Above_MSL))
                   waitcnt (clkfreq * 4 + cnt)
    Pub ShortBlink
           repeat 8
              !outa[noparse][[/noparse]16]
              waitcnt(9000_000 + cnt)
    PUB TakeReading
         latavg  := gps.Float_Latitude_Deg
         longavg := gps.Float_Longitude_Deg
        { -======Not working.  Locks up========-
        long1 := lat1 := 0.0
        repeat 10
           lat1 := f.fadd(lat1,gps.Float_Latitude_Deg)
           long1 := f.fadd(long1,gps.Float_Longitude_Deg)
        latavg := f.fdiv(lat1,10.0)
        longavg := f.fdiv(long1,10.0)
    Pub Term1
           DEBUG.Position(20,10)
           DEBUG.str(string("Fix Quality: "))
           DEBUG.Position(20,12)
           DEBUG.str(string("Number of Sats: "))
           DEBUG.Position(20,14)
           DEBUG.str(string("Reading Number: "))
           DEBUG.Position(20,16)
           DEBUG.str(string("Long: "))
           DEBUG.Position(20,18)
           DEBUG.str(string("Lat: "))
    Pub Term2
                  DEBUG.Position(34,10)
                  DEBUG.clearend
                  DEBUG.dec(gps.Long_Fix_Quality)
                  DEBUG.Position(37,12)
                  DEBUG.clearend
                  DEBUG.dec(gps.Long_SatID_In_Fix(0))
                  DEBUG.Position(37,14)
                  DEBUG.clearend
                  DEBUG.dec(x)
                  DEBUG.Position(27,16)
                  DEBUG.clearend
                  DEBUG.str(fs.floattostring(longavg))
                  DEBUG.Position(27,18)
                  DEBUG.clearend
                  DEBUG.str(fs.floattostring(latavg))
  • max72max72 Posts: 1,155
    If you only want to save to SD card you don't need the float routines. You can simply get the strings from the GPS, and parse the fields you are interested in in the SD card.
    Check
    obex.parallax.com/objects/579/
    (only one cog, I haven't tested it yet)
    and
    obex.parallax.com/objects/225/
    (2 cogs, the GPS parsing engine works very well)
    Massimo
