D/A chip for low frequency
Howdy guys, I am currently starting on the prop, I have held off way too long on this. I have been playing with the basic stamp for about 7 years and I need more power for what I am doing now.
What would you recomend for a Digital to Analog converter for low frequency range of 0.1 Hz to 12 Hz generation. I am currently working on a multichannel programable LFO and I want control over the PWM, phase and Amplitude·of the signal. Any sugetions? I have the Prop, regulators·and a 5Mhz crystal on order right now and just need a good choice for the Digital to analog. I'm also looking to do level detection so I will need an A/D also but thats not so critical at the moment.·
Leon Heller
Amateur radio callsign: G1HSM
I also need it to be in DIP form. surface mount is a bit tough for my old hands.
on a side note is thier an I2C LCD avalible?
Post Edited (Pablo1234) : 5/15/2010 3:38:17 PM GMT
There are LCDs with serial interfaces, so there might I2C ones. I made my own serial LCD using an AVR, and I've often thought of making an I2C or SPI version.
Leon Heller
If one of the counters of a cog is initialized in DUTY mode, you only need to write the DAC value to the PHSx register.
So you can have 2 RC-DACs per cog.
The following code outputs a value at pin PA0 and increases it all 2 seconds.
Andy
This is the DAC I'm looking at right now.
I don't want to do square wave outs and integrate them, I want control over the shape of the wave Tri, Saw, reverse saw and sine from .0 hz to 12 hz. I also need control over the amplitude and phase. doing this in anolog with a pulse output is how I am currently doing it with a basic stamp and its alot of extra circuitry, intigrator for square to·Tri or Saw·and high pass filter to readjust amplitude and set sine. Total pain in the but.
www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1156,P2333
The buffered output will save you having to provide a buffer.
Linear is very liberal with free samples.
Leon Heller
With the Propeller there's much less external circuitry needed to get what you want. Here's a program I wrote to output low-frequency sine waves:
It uses a counter's DUTY mode output and the exact RC network that Andy showed above to filter it. Here's what the output looks like:
It's hardly what I'd call a "pain in the butt".
Addendum: BTW, this is the raw output from the pin that the RC network is filtering:
'Notice the frequency and time scale? 12Hz is glacial by comparison.
Post Edited (Phil Pilgrim (PhiPi)) : 5/16/2010 9:17:19 PM GMT
I need 6 programable LFO's so the 8 channel will save me some pins
Here's some output that alternates between sine and sawtooth every cycle:
Andy's RC filter was a bit too aggressive for a sawtooth waveform, so I reduced the resistor to 6.8K to obtain this scope trace.
I am getting sick as a dog but I think I can program from bed lol.
The main isue I had with integrating with an CR network on my stamp was that it would go from a tri wave at high freq to a saw at the lower frequencys. also the amplitude would change. I need to look more into how the Prop is programed and what its limitations are but I beleve I will be able to get closer to what I want with it x10. Some of the projects you guys have done are super impressive. I love the cnc router project.
I also have been reading the docs and I think I'm gona try the bst with PropBasic unless someone thinks it would be better for me to use Spin. I am very unfamiler with Spin, Multicore programing and the Propellor. I am very familer with PBasic, VB 6 and computer programing though.
Could someone start me off with PropBasic by rewriting this Spin Phil wrote the other day?
ok I wana try and break this down to see if I under stand it
this sets the·prop to the external crystal _xinfreq at 5,000,000 and xtal1 sets the proper internal RC network for the crystal and pll16x is the multiplier of _xinfreq x 16 = 80,000,000 hz
so ctra and ctrb will incrament every 12.5 microseconds with no modifiers.
the rest i get but I am a bianary person not boolian·so BITSHIFTING and·useing OR to add numbers kinda complicates it a bit for me. Not that I dont understand the·concept but i'm not understanding why you shift 0 (OUTPIN) to the 26th bit of ctra.
then phase an internal variable to the subroutine·is reset to 0 useing ~
dt is then set to··dt·:=·clkfreq·/·1000·= 80,000
then t is set to the current count + 80,000
so all that would be the initalization for the return loop that follows it. and the sin is a look up table in the rom to offset the amplitude to create a sin wave from a ramped signal.
I know I dont fully understand this yet but I want to.
Post Edited (Pablo1234) : 5/20/2010 10:29:02 PM GMT
So how do I detect my on time and off time, not in the duty but the output. Say I want to have a triangle wave that ramps up·for 100mS and ramps down for 66mS. This would be on for·5/8ths and off for 3/8ths of 6Hz. I want to specify frequency and change·the duty of my output wave.
How do·I make an offset of my phase relationship between LFO 1·,2, 3, 4, 5, 6? and at what incrament would it be in. at 12Hz and 1 mS slice time·I am gessing 2.3 deg phase incraments, correct?
A woman is the only thing I am afraid of that I know will not hurt me. - Abraham Lincoln
