okay, finished my version of the propeller servo controller firmware.
I modified the base firmware that it comes with to controll my animatronic costume. I think it will work, but I cant be sure as of yet. as I need to get the wings mounted on something so I can test them and set endpoints properly. and connect the i2c rgb led array together and get it mounted.
I can post the code if anyone is interested. its not really that much different, but it might give someone some ideas.
Learning curves as greatly reduced when you see how someone else does it [noparse]:)[/noparse]
Mark
